Hi.
Is there a way we can see the details/image of all types of connections in the RAM Connection Library (integrated in STAAD)?
If there are types of connection that are not available, could you suggest what software to use or which is better, RAM Connection Standalone or the one that is integrated in STAAD?
Currently, we have the latter but we have several types of connections we shoul use but are not available in the RAM and I believe, it is not possible to create custom connections unless it is a Standalone.
Looking forward to hearing from someone who could help and advise me on this matter.
Tak.
These are some of the connections we need to use in our current project and I believe these are not available in the RAM Connection module in STAAD.Pro.
Please correct me if I'm wrong.
Do you happen to know if these are available in LIMCON? Also, could we make custom connections like these in LIMCON or RAM Connection Standalone?
Lastly, does LIMCON work like a RAM Connection module and will also require additional license?
As Modestas answered the connections available in Staad.Pro are generally the same as those available in RAM Connection:
In Limcon the following connections can be modelled/designed:
From the images you provided you could use the single brace above to design the bolted connection to the brace members. The other connections shown on your pictures are nonstandard and would need to be designed by hand.
