Hi
I did export from Staadpro to Prosteel by ISM. Then i create a New From Repository in Prosteel but something wrong happen. That is system said that "Can not found the section" , (you guys can see detail in this picture here) while i did use them in the same standars is AISC. So how can i fix this problem? Any thought? Thank you all for attention!
Hi Junying Chen,
What versions of STAAD and ProSteel are you using? What version of Structural Synchronizer do you have? Could you upload your STAAD model for review?
Steve
Hi Steve Crabtree.
I used version StaadPro V8i SS6 20.07.11.50, Pro Steel 08.11.11.45, Structural Synchronizer 10.00.01.06
You see the file and help me fix error.
Thank you very much
2437.0602.M703-IA-P0.std
Answer Verified By: junying chen
Hi Steve Crabtre!
Thanks for answer my question.
When I import the model into autocad appear this error . I do not know how to load the mapping file where, Can you just help me mapping file anywhere?
Thank you!
