Hi everyone!
I wanted to create a base plate joint from RAM connection, after analyzed by Stadd pro but it didn't work. appeared a notification conveyed that: " no connections have been designed ".
See the file bellow:
62016 HANDRAIL STRUCTURE.std
thanks you!
Hi Modestas.
what a disappointing! if RAM connection can not design base plates with inclined columns. Do you have any solution to resolve this problem?
If I use Ram Structural System V8i, is it useful?
Hope you can solve this, really thank!
