Hi All,
I am designing a Multistory RCC Building for Bus Depot. I have a dought regarding Member (Beam) Releses
How would I decide what releases has to be given at Start or End position of Beam for the Following conditions
1) Main Beam with Both ends resting on column
2) Beam with one end resting on column and other end resting on Beam
3) Secondary Beam with both ends resting on Main Beams
4) Cantilever Beams with one end resting on column and other end Free
Please help me for my doughts in Member Releases for RCC Structures
Thank you
The two way floor load is reported in the Output file as a series of concentrated loads (CON).L shaped concrete beams can be designed in the Advanced Concrete Design workflow (RCDC) in STAAD.Pro CONNECT Edition.
