Hi everybody!
I have a problem, arrangement rebar for column as the figure below:
The problem is: how can I change the quantity, the type, dimension of reinforcements
Thank all.
If you are not aware, you can apply commands like MAXMAIN, MAXSEC, MINMAIN and MINSEC for defining the Maximum to Minimum range of diameter to choose from for Main and Secondary bars. These options can accessed from Define Parameters option on the Design Tab. An image is attached for your reference:
Hope this helps.
