wind load output results
Hi Everyone
I have modeled a building and used the wind generation tool according to ASCE 2010 to get my wind loading. However, when I access the results in post processing, under the beams>graphs sub-tab, and select any column the Mz graph is not giving the correct values. I have attached a picture to demonstrate my result under the wind load loading, as well as the Staad pro file. Any assistance will be highly appreciated.
academic block hurricane.zip
