AISC 360-10, Chpt. J code checking
In STAAD.Pro, code checking for AISC 360-10 is typically for chapters B-H (I don't use chapter I for my work anyway). Specifically, there are considerations in Chapter J that must also be considered for use in Chpts. B-H. Using the highest TRACK 2 setting, I still see no output or options for STAAD to check applicable Chpt. J sections, especially J10.
Are there any commands or options for STAAD to check these requirements? Any suggestions?
Thanks!
