STAAD - "GENERATE" command
I'm using "GENERATE" command to model continuous supports at the base of my my shear walls (surface elements). How do I extract the reactions on the nodes that are internally generated by the program i.e. nodes between the starting (ni) and ending nodes (nj)?
Dennis
Parents Reply
  • Unfortunately the limitations that I mentioned above exists in STAAD.Pro till date. So looking at the reactions in the analysis output file is still the only option.
    However regarding viewing the intermediate nodes graphically, there is a way.
    Listed below is a series of steps that you can take to convert the surfaces to plates which would allow you to graphically view the generated intermediate nodes.
    1. Save your STAAD model file by a different name.
    2. Analyze the saved STAAD.Pro model.
    3. Press “F12” key on the keyboard which is going to convert the surface to constituent nodes and plates.
    4. You will NOT see the plates at first. Save the file. Close it and reopen it and you will see the plates.
    5. The model will generate some errors while opening as all information related to the surfaces are not completely deleted from the file.
    6. You can turn the node numbers on to check the location of the intermediate nodes
