I am getting this error when I try and run the steel and column module??? Can I send you my model to see if you can find the issue?
Here are some general tips related to that kind of issue.
To send the file, use the Secure File Upload instructions.
Smaller files can be attached directly in a forum post or reply with the Advanced Reply Editor (use the Insert media tool), but for RAM SS files you will probably have to upload separately.
I also am having an this same issue when I try and enter the beam module. I've uploaded my file (Tada Portlock), any help would be appreciated!
Thank you!
These hip roofs with long slab edges using 0" slab offsets are tricky. I found that if I replaced the slab edge on the Low Roof level, East side, with one whole perimeter slab edge (4'9" offset), then it was OK. You can reduce the slab edge where you don't want such a large overhang afterwards, but keep it offset outboard at least 1". Alternatively use a small overhang all around and supplement the perimeter beams or walls with line loads.
That seems to have worked. Thanks for the help.
I went through the list and am having a similar problem with the AdvanceNodeList() error. I have sent my model through the secure file upload.
