I am getting this error when I try and run the steel and column module??? Can I send you my model to see if you can find the issue?
There are some intersecting walls that need to be split. I also see some slight variation in the coordinates.
thank you for the response. Now I am having an issue in the Concrete Gravity Analysis. I am receiving an error "Tolerance error at story FIRST FLOOR, coordinate (x,y,z)". I tried to align all the members in that area but am still getting this error. I sent the file to the secure file upload.
I have sent in a model with a similar issue, but have checked the walls and could not find a wall that needs to be split. I do not have any errors when I do a data check. I am receiving the "Advance..." error when I try to design the steel beams. Thank you!
Having the same error as listed in this thread. My file should be uploaded.
Weston, I sent a reply back via the service request that you submitted. If you have any follow-up questions, please reply back to that e-mail.
