Total beam length in steel beam module
Is it possible in RAM Structural System/RAM Steel for it to design/analyze beams based on the length from column face to column face instead of center to center of column supports?  I am back engineering a building that appears to have been designed to very precise limits of the members and the total beam length reduction is a factor.
If not, is this possible in other RAM software such as RAM Elements?
Parents Reply Children
