I am facing a problem with reference to the Staad pro v9i SS6. Please help in solving the same if its a known bug or a workaround is available.
I have imported the load data for seismic in all 6 directions (+/-X,+/-Y, +/-Z ) This is a Z up model and X & Y are Horizontal directions
When i am running the model with full loading, I get different reactions for +/-X & +/Y even though the inputted vaules summation are the same
Load Cases
8 SEISMIC_+X9 SEISMIC_-X10 SEISMIC_+Y11 SEISMIC_-Y12 SEISMIC_+Z13 SEISMIC_-Z
Equipment Loading with self weight
Equipment Loading without Selfweight (all Values are matching in both directions Fx and Fy = 693.3 kN)
Only Self Weight
In the above it is very well seen that the Total Value needs to be 693.3 + 45.542 = 738.84 for all load cases (8,,9, 10, 11) but i am getting lower value for + / - Y Direction
which is actually 693.3 - 45.542 = 647.76
Kindly look into the issue and suggest possible solution.
Ram
Answer Verified By: Ramprasath N
