Is there any way to remove releases from specified beam using OpenStaad?
Go to OpenSTAAD Help and see "Property.CreateMemberReleaseSpec" and "Property.AssignMemberSpecToBeam". I tried it and it seems there is a bug in the Assign function. Regardless of the argument I pass the function for the spec number it always assigns it to the first release spec in the list. Also, setting all releases to zero makes for a fairly clunky result in that it actually makes an empty release spec. These functions are not cool.
