Overturning Moments on Shear Walls
I have a model with 5 stories of wood on top of a transfer slab with 2 levels of concrete below.  The wood portion is laterally supported by wood shear walls and the concrete levels have concrete shear walls.  When designing the concrete shear walls below, does ram account for the height at which the applied lateral loads act on the wood levels to increase the global overturning in the system as compared to just applying a lateral load at the transfer slab equal to the sum of the lateral loads on the wood levels above?
Additionally, when I investigate the overturning moments of the concrete shear walls at the base I am finding that the overturning moment (in-plane of the wall) is less than the sum of the applied shear loads multiplied by their respective heights.  Why is this?
Parents Reply
  • Karl,
    I have all the levels included and have not entered any lateral loads manually so by your explanation Ram should capture the global overturning.
    Some of the wood walls at the upper levels (which were modeled as "other" walls) do intersect and probably are creating the vertical components of force you are suggesting. However, if I use the blue frame story shear arrow in the frame module and isolate the shears applied at only the concrete levels for any particular wall/frame (not accounting for any of the wood loads above) the overturning from the reports is still less than these shears multiplied by their heights. Can you explain this? Seems to me it would be at a minimum equal to the shears at the concrete levels times the heights, and that is with no additional overturning from the wood levels above.
