hello I am tying to generate floor load but when but when I input the range and generate the load it says "cannot generate load for command Y range" does any body know what is causing this problem?
7103.frame.std
I experienced this too and this is what I did. If the drawing is an imported DXF, make sure the dimension units are in Meters instead of millimeters
