Could you guide me how to create drawing from saved view please. I have go t no seed files to choose in the list hence I can not create drawing from the saved views. How can I set it.
Boney
Hi Marc,
It seems picking up the .dgnlibs you mentioned. Please find attached the screen shot as requested. Thanks for you reply.
Just as quick test please run the key-in expand echo $(MS_DRAWINGSEED_LIBLIST) and post the results here
For an out of the box install it should return these two dgnlibs in the message center, however I'm assuming that you are connected to a network so expect different values to these:
C:\ProgramData\Bentley\AECOsimBuildingDesigner V8i Ss6\WorkSpace\BuildingDatasets\Dataset_GB\dgnlib\DrawingSeed_Architectural.dgnlib
C:\ProgramData\Bentley\AECOsimBuildingDesigner V8i Ss6\WorkSpace\BuildingDatasets\Dataset_GB\dgnlib\DrawingSeed_General.dgnlib
Your screen shot shows that the model seeds (greyed out in the Create Drawing and Sheet model sections) is modelseed.dgn. This file is used when new Models are created in the Models dialog, the Create Drawing dialog should always use a DrawingSeed*.dgnlib.
Either the configuration is incorrect or you are for some reason not connected correctly to it so are picking up incorrect configuration values.
Marc
