Could you guide me how to create drawing from saved view please. I have go t no seed files to choose in the list hence I can not create drawing from the saved views. How can I set it.
Boney
We recommend always using the callout tools, they are integrated with the discipline specifc Drawing Seed Models so you get the right settings and have less manual steps to execute.
However if you use the 'Create Saved View' tool ensure that you select the View Type when you create the Saved View, this will give you access the the Drawing Seed Models when you manually start the Create Drawing dialog
Existing Saved Views, where the Type was not selected, can be changed from 'Saved View' to Plan, Section, Elevation and Detail views by right-clicking on the view in the Saved View dialog and picking Properties, change the Type in the General panel. Once set to Plan, Section, Elevation or Detail the view type is fixed. When you go to Create Drawing the Drawing Seed Models will be listed.
Marc
Answer Verified By: Boney Chandy
Thanks for the tip could never understand why I had no seed assigned to my saved view dialog dropdown.
