Good Day,
I am currently modelling a staircase supported by a moment frame and I have come across a strange occurrence. When I checked my column forces the axial forces seemed alright but the moments were strange as the moments generated along the top portion of my column is greater that that of the lower portions and supports, which seems incorrect based on the theory of bending moment. The model I generated employed the use of beam elements for my columns and beams and plate elements for my columns. I have included the Staad file for inspection.
Thanks. STAIRS-frame.zip
Hello Gilbert Fontenard,
Sir I have downloaded your STAAD file in order to review your Error but sir I did not find any inaccuracy in the STAAD report as it may be the case after final moment distribution of the various members, its not necessary that the top column has to have lower moments then the bottom column rather top column will have less axial force than the bottom column.
I have attached a pdf file in order to give a clear indication of the moments distribution method please view it and let me know if it has solved your query.
