PLEASE HELP I HAVE SHARED A SAMPLE FILE HERE PLEASE HELP AND TELL HOW DO I RESOLVE2330.beams.std
Modified model has been attached.
3324.2330.beams.std
Please ensure that your support is defined before you define the load as shown next
MEMBER PROPERTY
1 PRIS YD 0.5 ZD 0.3
SUPPORTS <- Revised Location
1 2 FIXED <- Revised Location
LOAD 1 LOADTYPE None TITLE LOAD CASE 1
JOINT LOAD
1 2 FY -50
MEMBER LOAD
1 UNI GY -45
PERFORM ANALYSIS
*SUPPORTS <- Original Location
*1 2 FIXED <- Original Location
Also there was no material assignment in the file. The concrete material was defined but not assigned to the member. So the following commands were assigned
CONSTANTS
MATERIAL CONCRETE ALL
The additional PERFROM ANALYSIS command was also commented out.
Modified file is attached for your reference.
2330.beams_modified.std
hi, i have the same problem. can anyone help me? I have 2 files here.
TERRACE.stdSH LATEST 29 MARCH.std
