Divergent in load cases
Dears,
I 've attached STAAD model that shows warning about divergent of some load cases while analysing by Direct Analysis Method. Can you tell me the source of the problem and how to fix it, if possible can you treat the attached model.
Regards,J13076-0100D-AR-503-Rev3-trial.std
