Deflection is not showing in output
Hi all,
I used all parameters for deflection such as DFF UNT UNB LY LZ , but output doesn't show the deflection check, also please advise how to find maximum deflection for each load case, if any command is there
Skid Lifting.std
  • For the deflection checks to be carried out as per the AISC 360 codes, you need to define serviceability ( and strength ) envelopes before you do the design. Please refer to the following wiki for details on how to set up the design
    http://communities.bentley.com/products/structural/structural_analysis___design/w/structural_analysis_and_design__wiki/20793.strengthserviceability-check-in-design
    In case you need to carry out both strength and deflection checks for the same load, please refer to the following wiki
    http://communities.bentley.com/products/structural/structural_analysis___design/w/structural_analysis_and_design__wiki/23987.serviceability-and-strength-check-for-the-same-load-combination
    Also while looking into your model, I found that you did not have a CHECK CODE command following your second set of design ( corresponding to PARAMATER 2 ). You may want to add that.
  • Hi,
    Thanks now I did the deflection check for other type and I got the deflection result but it shows fail in header but pass in content. can you clarify why this happens?
     *     1 ST   W12X40                   (AISC SECTIONS)
                               FAIL   DEFLECTION           0.046       100
                            0.00 C          0.00           0.00      472.44
    | DEFLECTION CHECK:   (UNIT: INCH)                                      |
    | Limit Span/Deflection (DFF) :  240.000   Limit      :     1.969       |
    | Span/Deflection             :  5.26E+03  Deflection :     0.090       |
    | L/C                         :   100      LOC        :   472           |
    | Ratio                       :     0.046  (PASS)                       |
    |-----------------------------------------------------------------------|In-Place.std
  • I see consistent results reported and both sections of design report a PASS as seen below.
    I think it is your version. Please update the software to the latest version ( 20.07.11.82 ) and it should take care of the issue.
Reply Children
