I am looking to extract some information from RAM using a VBA. Currently, I am specifically looking to extract the Max Shear (Max VEd) and the Shear force used to calculate the capacity (VEd). I have looked into RAM DataAcess and writing codes to extract information - able to extra beam/column size, UID, X,Y,Z coordinate etc.
I have attempted to extract the shear force using IAnalyticalResult>IMemberForces>GetMaximumComboReactions>IMemberForce.dShearMajor. This method does give me some data but when I check it against RAM, I am unsure of what information is actually pulled out from RAM? Is this the correct way of obtaining design results?
Also, what can be extracted from RAM (in terms of results) as I know most properties can be easily extracted.
Thanks in advance,
Russell
