Modelling shear wall support
Good day,
I would like to find out how best can the supports for a shear wall be modeled. Considering the footing under a shear wall is continuous, placing fixed footing at the ends of the wall would suggest that the wall is only supported at these point, which in my view is inaccurate. Is it acceptable to model a shear wall supported by multiple fixed footings to simulate a continuous type of fixed foundation?
I have included an image as well as a model to illustrate this concept.
 wall example.zip
Parents Reply
  • I don't think that this warning will affect your results.
    Please note that your horizontal slab is not quite correctly connected to the shear walls. The shear walls by default are divided into 10x10 mesh size. So the shear walls are internally divided into 10 pieces at the edge. While a horizontal slab is divided into a 4 pieces, the connectivity between the slab and shear wall is not quite correct. You need to mesh the horizontal slab using a 10x10 or at least 5x5 mesh size.
    Answer Verified By: Gilbert Fontenard
