For Steel structures we use 2 parameters set:
First one is to design the steel structures per code requirements (ASD, LRFD)Second one is to obtain check deflections from STAAD (output file)
******************************************************************************************------------------------STEEL DESIGN-------------------------***------------------------DESIGN PARAMETERS-------------------------**************************************************************************************LOAD LIST 200 210 220 230 TO 233 240 TO 247 250 TO 253 260 TO 267 270 TO 273 -280 TO 287**************************************************************************************PARAMETER 1CODE AISC UNIFIED 2010*************************************************************************************** MATERIALES** A992 - A572 GRADE 50 (Fy = 50ksi - Fu = 65ksi) / W-SHAPES, HP-SHAPES* t/M² = FYLD 35150 - FU 45696*FU 45696 MEMB _C-1FU 45696 MEMB _V-1FU 45696 MEMB _V-2FU 45696 MEMB _V-3FU 45696 MEMB _V-4FU 45696 MEMB _CV-1FU 45696 MEMB _CV-2*FYLD 35150 MEMB _C-1FYLD 35150 MEMB _V-1FYLD 35150 MEMB _V-2FYLD 35150 MEMB _V-3FYLD 35150 MEMB _V-4FYLD 35150 MEMB _CV-1FYLD 35150 MEMB _CV-2** A36 (Fy = 36ksi - Fu = 58ksi) / M & S-SHAPES, CHANNELS, ANGLES* t/M² = FYLD 25308 - FU 40775*FU 40775 MEMB _CH-1*FYLD 25308 MEMB _CH-1** A500 GRADE B (Fy = 46ksi - Fu = 58ksi) / ROUND & RECTANGULAR HSS* t/M² = FYLD 32338 - FU 40775***************************************************************************************** As per steel construction manual chapter E para E2 KL/ry for compresion* member preferably should not exceed 200*MAIN 200 MEMB _C-1MAIN 200 MEMB _V-1MAIN 200 MEMB _V-3MAIN 200 MEMB _V-4MAIN 200 MEMB _CV-1MAIN 200 MEMB _CV-2MAIN 200 MEMB _CH-1**** As per steel construction manual chapter D para D1 KL/ry for Tension** member preferably should not exceed 300*TMAIN 300 MEMB _C-1TMAIN 300 MEMB _V-1TMAIN 300 MEMB _V-3TMAIN 300 MEMB _V-4TMAIN 300 MEMB _CV-1TMAIN 300 MEMB _CV-2TMAIN 300 MEMB _CH-1*RATIO 0.9 MEMB _C-1RATIO 0.9 MEMB _V-1RATIO 0.9 MEMB _V-2RATIO 0.9 MEMB _V-3RATIO 0.9 MEMB _V-4RATIO 0.9 MEMB _CV-1RATIO 0.9 MEMB _CV-2RATIO 0.9 MEMB _CH-1*NSF 0.8 MEMB _C-1NSF 0.8 MEMB _V-1NSF 0.8 MEMB _V-2NSF 0.8 MEMB _V-3NSF 0.8 MEMB _V-4NSF 0.8 MEMB _CH-1NSF 0.8 MEMB _CV-1NSF 0.8 MEMB _CV-2*LZ 2.7 MEMB _V-1LZ 3.45 MEMB _V-2LZ 3.45 MEMB _V-3LY 5.4 MEMB _V-1LZ 3.45 MEMB _V-2LY 3.45 MEMB _V-3*UNB 5.4 MEMB _V-1UNT 5.4 MEMB _V-1UNB 3.45 MEMB _V-2UNT 3.45 MEMB _V-2UNB 3.45 MEMB _V-3UNT 3.45 MEMB _V-3*KY 1 MEMB _C-1KZ 1 MEMB _C-1*METHOD ASD*TRACK 0 MEMB _C-1TRACK 0 MEMB _V-1TRACK 0 MEMB _V-2TRACK 0 MEMB _V-3TRACK 0 MEMB _V-4TRACK 0 MEMB _CH-1TRACK 0 MEMB _CV-1TRACK 0 MEMB _CV-2*CHECK CODE MEMB _C-1CHECK CODE MEMB _V-1CHECK CODE MEMB _V-2CHECK CODE MEMB _V-3CHECK CODE MEMB _V-4CHECK CODE MEMB _CH-1CHECK CODE MEMB _CV-1CHECK CODE MEMB _CV-2*STEEL TAKE OFF ALL*****************************************************************************************------------------------ DEFLECTION CHECK -------------------------**************************************************************************************LOAD LIST ENV 10**************************************************************************************PARAMETER 2CODE AISC UNIFIED 2010*************************************************************************************** MATERIALES** A992 - A572 GRADE 50 (Fy = 50ksi - Fu = 65ksi) / W-SHAPES, HP-SHAPES* t/M² = FYLD 35150 - FU 45696*FU 45696 MEMB _C-1FU 45696 MEMB _V-1FU 45696 MEMB _V-2FU 45696 MEMB _V-3FU 45696 MEMB _V-4FU 45696 MEMB _CV-1FU 45696 MEMB _CV-2*FYLD 35150 MEMB _C-1FYLD 35150 MEMB _V-1FYLD 35150 MEMB _V-2FYLD 35150 MEMB _V-3FYLD 35150 MEMB _V-4FYLD 35150 MEMB _CV-1FYLD 35150 MEMB _CV-2** A36 (Fy = 36ksi - Fu = 58ksi) / M & S-SHAPES, CHANNELS, ANGLES* t/M² = FYLD 25308 - FU 40775*FU 40775 MEMB _CH-1*FYLD 25308 MEMB _CH-1** A500 GRADE B (Fy = 46ksi - Fu = 58ksi) / ROUND & RECTANGULAR HSS* t/M² = FYLD 32338 - FU 40775**************************************************************************************DFF 480 MEMB _V-1DFF 480 MEMB _V-2DFF 480 MEMB _V-3DFF 480 MEMB _V-4** V-1DJ1 7 MEMB 17 18DJ2 9 MEMB 17 18DJ1 9 MEMB 19 20DJ2 11 MEMB 19 20DJ1 17 MEMB 37 38DJ2 19 MEMB 37 38DJ1 19 MEMB 39 40DJ2 21 MEMB 39 40DJ1 27 MEMB 60 61DJ2 29 MEMB 60 61DJ1 29 MEMB 62 63DJ2 31 MEMB 62 63* V-2DJ1 7 MEMB 21 31DJ2 17 MEMB 21 31DJ1 11 MEMB 26 36DJ2 21 MEMB 26 36DJ1 17 MEMB 41 54DJ2 27 MEMB 41 54DJ1 21 MEMB 49 59DJ2 31 MEMB 49 59* V-3DJ1 8 MEMB 22 32DJ2 18 MEMB 22 32DJ1 9 MEMB 23 33DJ2 19 MEMB 23 33DJ1 10 MEMB 24 34DJ2 20 MEMB 24 34DJ1 18 MEMB 43 55DJ2 28 MEMB 43 55DJ1 19 MEMB 45 56DJ2 29 MEMB 45 56DJ1 20 MEMB 47 57DJ2 30 MEMB 47 57*METHOD ASD*TRACK 0 MEMB _V-1TRACK 0 MEMB _V-2TRACK 0 MEMB _V-3TRACK 0 MEMB _V-4*CHECK CODE MEMB _V-1CHECK CODE MEMB _V-2CHECK CODE MEMB _V-3CHECK CODE MEMB _V-4*STEEL TAKE OFF ALL**************************************************************************************
this in order to obtain the deflection check from STAAD output, but when verifying the ratios with symbols and labels / design results or from postprocessing / beam / unity check, only the second parameter results are shown even when the first parameter result is the maximum ratio, is there a way to make both analysis and obtain both results (design and deflection check) but when checking the ratio's diagram obtain the maximum one (the critical condition)?
If yes can you explain the steps to obtain this?
If there are multiple design sets, the results for the last set is displayed in the Beam Unity check tables or when plotting the design ratios. More explanation on this and a couple of workarounds can be found in the following wiki
http://communities.bentley.com/products/structural/structural_analysis___design/w/structural_analysis_and_design__wiki/29116.seeing-multiple-sets-of-design-in-the-same-staad-file
The good news is that, this limitation in the software, which has existed for years, is going to be addressed in the near future as major changes in the software architecture is being carried out. For now, if you have two sets of designs, the only way to see the results for both sets would be using the analysis output file and each would report it’s own critical ratio. The only way to get STAAD.Pro to report the critical out of the strength and the deflection checks, is to include both strength and serviceability envelopes as part of the LOAD LIST ENV command.
