I'm trying to see the steel design in the output. The report is only showing one beam (first page only). It won't show the steel design output beyond the first beam. Is there a reason for this? The utilization ratio table shows all the beams and this can work for now, but I would like to see the steel design output that was used. I've used the following for the input for the steel design:
DEFINE ENVELOPE
500 TO 503 508 TO 519 530 TO 541 ENVELOPE 1 TYPE STRENGTH
620 TO 623 ENVELOPE 2 TYPE SERVICEABILITY
END DEFINE ENVELOPE
LOAD LIST ENV 1
PARAMETER 1
CODE AISC UNIFIED 2010
METHOD LRFD
. (other parameters here not listed to save space)
TRACK 1 ALL
CHECK CODE ALL
FINISH
Jeremy,Can I have your input file uploaded for a better understanding of reported problem please? Please use Secure File upload link in order to upload the requested file.Regards,
See the attached file. I haven't attached a file before. Hopefully this works.
SouthLobbyFraming-Diaphragm.std
Thanks Jeremy. I executed the input as it was received and noticed STEEL design results for ALL were reported in ANL file. See the attachment.I'm using STAAD.Pro SS6 20.07.11.82
Input n output.zip
Answer Verified By: Jeremy Jacobs
