load combinations with euro code
How can I create an automatic load combinations with Euro code? if not, who knows a code has the same combinations in Euro? staad can check with Euro code and can't generate load combinations with Euro ??!! Thanks in advance ..
  • Please go through the attached document
    Hope, this helps you.
  • Please refer to the following picture which explains the process to generate Auto Load combination as per Euro code.
  • Great thanks dear .. last question ,, seismic definition (static ) can't be performed by EURO code .. is this process is allowed or only in Response spectrum definition ..
  • Seismic analysis can be performed only as a Response Spectrum Analysis as per EC8. Static seismic method is not implemented.
