Vertical and roof Truss design
Hi, I really need help.
I am trying to design an open warehouse made of steel truss roof and column. I keep on getting joint instability on one of my support. I don't know if what I did was right in my modelling process. Should I separate the design of the roof truss from the vertical column? Is that possible?
  • If you can upload your model, we can take a look and let you know why you are getting the instabilities.
    For now, here is a wiki page with some general information on instabilities and zero stiffness
    communities.bentley.com/.../2046.staad-pro-instability-and-zero-stiffness-faq
  • Hi! Can you help me to check my model.
    STAAD PLANE
    START JOB INFORMATION
    ENGINEER DATE 17-Aug-21
    JOB CLIENT Asia Tent International Sdn. Bhd.
    END JOB INFORMATION
    INPUT WIDTH 79
    UNIT METER KN
    JOINT COORDINATES
    4 0 0 0; 19 1 0 0; 20 1 1 0; 21 -1e-016 1 0; 22 1 2 0; 23 -1e-016 2 0;
    24 0 1 0; 25 1 3 0; 26 -1e-016 3 0; 27 0 2 0; 28 1 4 0; 29 -1e-016 4 0;
    30 0 3 0; 31 1 5 0; 32 -1e-016 5 0; 33 0 4 0; 34 1 6 0; 35 -1e-016 6 0;
    36 0 5 0; 37 1 7 0; 38 -1e-016 7 0; 39 0 6 0; 40 1 8 0; 41 -1e-016 8 0;
    42 0 7 0; 43 1 9 0; 44 -1e-016 9 0; 45 0 8 0; 46 1 10 0; 47 -1e-016 10 0;
    48 0 9 0; 49 1 11 0; 50 -1e-016 11 0; 51 0 10 0; 52 1 12 0; 53 -1e-016 12 0;
    54 0 11 0; 55 1 13 0; 56 -1e-016 13 0; 57 0 12 0; 58 1 14 0; 59 -1e-016 14 0;
    60 0 13 0; 61 1 15 0; 62 -1e-016 15 0; 63 0 14 0; 64 40 0 0; 65 41 0 0;
    66 41 1 0; 67 40 1 0; 68 41 2 0; 69 40 2 0; 70 41 3 0; 71 40 3 0; 72 41 4 0;
    73 40 4 0; 74 41 5 0; 75 40 5 0; 76 41 6 0; 77 40 6 0; 78 41 7 0; 79 40 7 0;
    80 41 8 0; 81 40 8 0; 82 41 9 0; 83 40 9 0; 84 41 10 0; 85 40 10 0; 86 41 11 0;
    87 40 11 0; 88 41 12 0; 89 40 12 0; 90 41 13 0; 91 40 13 0; 92 41 14 0;
    93 40 14 0; 94 41 15 0; 95 40 15 0; 96 -9e-016 15 0; 97 0.906694 16.1589 0;
    98 2.08761 16.3901 0; 99 1.81342 17.3177 0; 100 0.171876 16.6939 0;
    101 1.54378 15.695 0; 102 -1e-016 16.4742 0; 103 0.3609 16.9355 0;
    104 1.81125 17.315 0; 105 18.2623 22.2329 0; 106 18.5365 21.3052 0;
    107 20.5 21.3052 0; 108 22.7377 22.2329 0; 109 22.4635 21.3052 0;
    110 19.3812 22.5672 0; 111 20.5 22.9015 0; 112 19.5182 21.3052 0;
    113 21.6188 22.5672 0; 114 21.4818 21.3052 0; 115 10.0379 19.7753 0;
    116 10.3121 18.8477 0; 117 5.92565 18.5465 0; 118 6.19983 17.6189 0;
    119 3.86953 17.9321 0; 120 4.14372 17.0045 0; 121 7.98176 19.1609 0;
    122 8.25595 18.2333 0; 123 12.094 20.3897 0; 124 12.3682 19.4621 0;
    125 14.1501 21.0041 0; 126 14.4243 20.0764 0; 127 16.2062 21.6185 0;
    128 16.4804 20.6908 0; 129 3.11567 16.6973 0; 130 5.17178 17.3117 0;
    131 4.14373 17.0045 0; 132 3.86736 17.9293 0; 133 6.19984 17.6189 0;
    134 7.22789 17.9261 0; 135 5.92347 18.5437 0; 136 8.25595 18.2333 0;
    137 9.28401 18.5405 0; 138 8.25595 18.2333 0; 139 7.97959 19.1581 0;
    140 10.3121 18.8477 0; 141 11.3401 19.1549 0; 142 10.3121 18.8477 0;
    143 10.0357 19.7725 0; 144 12.3682 19.4621 0; 145 13.3962 19.7693 0;
    146 12.0918 20.3869 0; 147 14.4243 20.0764 0; 148 15.4523 20.3836 0;
    149 14.1479 21.0013 0; 150 16.4804 20.6908 0; 151 17.5084 20.998 0;
    152 16.4804 20.6908 0; 153 16.204 21.6157 0; 154 18.5365 21.3052 0;
    155 30.9621 19.7753 0; 156 30.6879 18.8477 0; 157 35.0744 18.5465 0;
    158 34.8002 17.6189 0; 159 37.1305 17.9321 0; 160 36.8563 17.0045 0;
    161 33.0182 19.1609 0; 162 32.7441 18.2333 0; 163 28.906 20.3897 0;
    164 28.6318 19.4621 0; 165 26.8499 21.0041 0; 166 26.5757 20.0764 0;
    167 24.7938 21.6185 0; 168 24.5196 20.6908 0; 169 39.1866 17.3177 0;
    170 37.8843 16.6973 0; 171 38.9124 16.3901 0; 172 39.1888 17.315 0;
    173 35.8282 17.3117 0; 174 36.8563 17.0045 0; 175 37.1326 17.9293 0;
    176 34.8002 17.6189 0; 177 33.7721 17.9261 0; 178 35.0765 18.5437 0;
    179 32.7441 18.2333 0; 180 31.716 18.5405 0; 181 32.744 18.2333 0;
    182 33.0204 19.1581 0; 183 30.6879 18.8477 0; 184 29.6599 19.1549 0;
    185 30.6879 18.8477 0; 186 30.9643 19.7725 0; 187 28.6318 19.4621 0;
    188 27.6038 19.7693 0; 189 28.9082 20.3869 0; 190 26.5757 20.0764 0;
    191 25.5477 20.3836 0; 192 26.8521 21.0013 0; 193 24.5196 20.6908 0;
    194 23.4916 20.998 0; 195 24.5196 20.6908 0; 196 24.796 21.6157 0;
    197 22.4635 21.3052 0; 198 40.0933 16.1589 0; 199 41 16.4742 0;
    200 40.6391 16.9355 0; 201 40.8281 16.6939 0; 202 39.4562 15.695 0;
    MEMBER INCIDENCES
    12 4 19; 13 19 20; 14 20 21; 15 21 4; 16 4 20; 17 20 22; 18 22 23; 19 23 24;
    20 22 25; 21 25 26; 22 26 27; 23 27 25; 24 25 28; 25 28 29; 26 29 30; 27 28 31;
    28 31 32; 29 32 33; 30 33 31; 31 31 34; 32 34 35; 33 35 36; 34 34 37; 35 37 38;
    36 38 39; 37 39 37; 38 37 40; 39 40 41; 40 41 42; 41 40 43; 42 43 44; 43 44 45;
    44 45 43; 45 43 46; 46 46 47; 47 47 48; 48 46 49; 49 49 50; 50 50 51; 51 51 49;
    52 49 52; 53 52 53; 54 53 54; 55 52 55; 56 55 56; 57 56 57; 58 57 55; 59 55 58;
    60 58 59; 61 59 60; 62 58 61; 63 61 62; 64 62 63; 65 63 61; 66 64 65; 67 65 66;
    68 66 67; 69 67 64; 70 64 66; 71 66 68; 72 68 69; 73 69 67; 74 68 70; 75 70 71;
    76 71 69; 77 69 70; 78 70 72; 79 72 73; 80 73 71; 81 72 74; 82 74 75; 83 75 73;
    84 73 74; 85 74 76; 86 76 77; 87 77 75; 88 76 78; 89 78 79; 90 79 77; 91 77 78;
    92 78 80; 93 80 81; 94 81 79; 95 80 82; 96 82 83; 97 83 81; 98 81 82; 99 82 84;
    100 84 85; 101 85 83; 102 84 86; 103 86 87; 104 87 85; 105 85 86; 106 86 88;
    107 88 89; 108 89 87; 109 88 90; 110 90 91; 111 91 89; 112 89 90; 113 90 92;
    114 92 93; 115 93 91; 116 92 94; 117 94 95; 118 95 93; 119 93 94; 120 96 97;
    121 61 101; 122 99 98; 123 100 97; 124 102 100; 125 62 102; 126 104 103;
    127 105 106; 128 106 112; 129 108 109; 130 105 110; 131 111 107; 132 107 114;
    133 111 112; 134 105 112; 135 112 110; 136 110 111; 137 108 113; 138 111 114;
    139 108 114; 140 114 113; 141 113 111; 142 104 101; 143 96 101; 144 97 99;
    145 115 116; 146 117 118; 147 119 120; 148 121 122; 149 123 124; 150 125 126;
    151 127 128; 152 99 119; 153 119 117; 154 117 121; 155 121 115; 156 115 123;
    157 123 125; 158 125 127; 159 127 105; 160 129 98; 161 104 129; 162 129 119;
    163 129 120; 164 130 131; 165 132 130; 166 130 117; 167 130 133; 168 134 133;
    169 135 134; 170 134 121; 171 134 136; 172 137 138; 173 139 137; 174 137 115;
    175 137 140; 176 141 142; 177 143 141; 178 141 123; 179 141 144; 180 145 144;
    181 146 145; 182 145 125; 183 145 147; 184 148 147; 185 149 148; 186 148 127;
    187 148 150; 188 151 152; 189 153 151; 190 151 105; 191 151 154; 192 155 156;
    193 157 158; 194 159 160; 195 161 162; 196 163 164; 197 165 166; 198 167 168;
    199 169 159; 200 159 157; 201 157 161; 202 161 155; 203 155 163; 204 163 165;
    205 165 167; 206 167 108; 207 170 171; 208 172 170; 209 170 159; 210 170 160;
    211 173 174; 212 175 173; 213 173 157; 214 173 176; 215 177 176; 216 178 177;
    217 177 161; 218 177 179; 219 180 181; 220 182 180; 221 180 155; 222 180 183;
    223 184 185; 224 186 184; 225 184 163; 226 184 187; 227 188 187; 228 189 188;
    229 188 165; 230 188 190; 231 191 190; 232 192 191; 233 191 167; 234 191 193;
    235 194 195; 236 196 194; 237 194 108; 238 194 197; 239 94 198; 240 95 202;
    241 199 201; 242 169 171; 243 201 198; 244 94 199; 245 172 200; 246 172 202;
    247 94 202; 248 198 169; 249 63 55; 250 57 49; 251 51 43; 252 45 37; 253 39 31;
    254 33 25; 255 27 20; 256 69 66; 257 73 70; 258 77 74; 259 81 78; 260 85 82;
    261 89 86; 262 93 90; 263 97 101; 264 101 98; 265 100 103; 266 112 107;
    267 114 109; 268 198 202; 269 202 171; 270 201 200;
    DEFINE MATERIAL START
    ISOTROPIC STEEL
    E 2.05e+008
    POISSON 0.3
    DENSITY 76.8195
    ALPHA 1.2e-005
    DAMP 0.03
    TYPE STEEL
    STRENGTH RY 1.5 RT 1.2
    END DEFINE MATERIAL
    CONSTANTS
    MATERIAL STEEL ALL
    MEMBER PROPERTY BRITISH
    12 13 15 17 19 20 22 24 26 27 29 31 33 34 36 38 40 41 43 45 47 48 50 52 54 -
    55 57 59 61 62 64 66 67 69 71 73 74 76 78 80 81 83 85 87 88 90 92 94 95 97 -
    99 101 102 104 106 108 109 111 113 115 116 118 TABLE ST TUB90904.0
    14 16 18 21 23 25 28 30 32 35 37 39 42 44 46 49 51 53 56 58 60 65 68 70 72 -
    75 77 79 82 84 86 89 91 93 96 98 100 103 105 107 110 112 114 119 249 TO 261 -
    262 TABLE ST TUB50503.0
    63 117 121 124 TO 126 128 130 132 136 137 141 152 TO 160 163 164 167 168 171 -
    172 175 176 179 180 183 184 187 188 191 199 TO 207 210 211 214 215 218 219 -
    222 223 226 227 230 231 234 235 238 240 241 244 245 264 TO 267 269 -
    270 TABLE ST TUB50502.5
    120 122 123 127 129 131 133 TO 135 138 TO 140 142 TO 151 161 162 165 166 169 -
    170 173 174 177 178 181 182 185 186 189 190 192 TO 198 208 209 212 213 216 -
    217 220 221 224 225 228 229 232 233 236 237 239 242 243 246 TO 248 263 -
    268 TABLE ST TUB40402.5
    SUPPORTS
    4 19 64 65 PINNED
    MEMBER RELEASE
    120 TO 248 263 TO 270 START MP 0.99
    120 TO 248 263 TO 270 END MP 0.99
    LOAD 1 LOADTYPE None TITLE DL
    MEMBER LOAD
    126 130 136 137 141 152 TO 159 199 TO 206 245 UNI GY -0.422
    SELFWEIGHT Y -1
    LOAD 2 LOADTYPE None TITLE LL
    MEMBER LOAD
    126 130 136 137 141 152 TO 159 199 TO 206 245 UNI GY -0.25
    LOAD 3 LOADTYPE None TITLE WL1
    MEMBER LOAD
    15 19 22 26 29 33 36 40 43 47 50 54 57 61 64 125 UNI GX 4
    LOAD 4 LOADTYPE None TITLE WL2
    MEMBER LOAD
    126 130 136 137 141 152 TO 159 199 TO 206 245 UNI GY -4
    LOAD 5 LOADTYPE None TITLE WL3
    MEMBER LOAD
    67 71 74 78 81 85 88 92 95 99 102 106 109 113 116 244 UNI GX -4
    LOAD 6 LOADTYPE None TITLE WL4
    MEMBER LOAD
    128 132 160 163 164 167 168 171 172 175 176 179 180 183 184 187 188 191 207 -
    210 211 214 215 218 219 222 223 226 227 230 231 234 235 238 266 -
    267 UNI GY 4
    LOAD COMB 7 COMBINATION LOAD CASE 7
    1 1.4 2 1.6
    LOAD COMB 8 COMBINATION LOAD CASE 8
    1 1.2 2 1.2 3 1.2
    LOAD COMB 9 COMBINATION LOAD CASE 9
    1 1.2 2 1.2 4 1.2
    LOAD COMB 10 COMBINATION LOAD CASE 10
    1 1.2 2 1.2 5 1.2
    LOAD COMB 11 COMBINATION LOAD CASE 11
    1 1.2 2 1.2 6 1.2
    PERFORM ANALYSIS
    PARAMETER 1
    CODE BS5950
    CHECK CODE ALL
    *LY 2 MEMB 152 TO 159 160 163 164 167 168 171 175 176 179 180 183 184 187 188 191 128 266 132 267
    *LZ 2 MEMB 152 TO 159 160 163 164 167 168 171 175 176 179 180 183 184 187 188 191 128 266 132 267
    PRINT ANALYSIS RESULTS
    FINISH
  • Why are you asking a new question on an existing thread? Anyway, did you look at the deflected shape? If you did you would have seen that many members that should be attached at the same node are not. You need to check for duplicate nodes and let the program merge any that are close to each other (say 25mm).
    Once you get this running properly you're going to find out that you members are severely undersized. If someone ask you to stand under this while they load test it, don't!
    How was this geometry generated? Was it from a CAD file? It may be instructive for others to know so they know what to watch out for.
Reply
