HELP ME PLEASE
VERTICAL PARKING_modified 2.std
Hello Rejoice Serrano,
This error actually pops up when there exist an element/plate/surface left with unassigned property I checked through your model and found that all of your plates are left unassigned so I defined a property for plate thickness assumed it to be 0.25m thick and assigned it to all of the plates in your model this has solved your error in the model. I would further instruct you to revise the thickness and element of the plate and assign it as per your requirement.VERTICAL PARKING_modified Solved.std
Watch this to rectify Modelling error: Missing Member Property & ELASTIC MODULUS (E) NOT ENTERED
