I CAN'T ASSIGN CABLE OR SOLID ROD ON MY PROJECT. WHAT WILL I DO? HELP ME PLEASE
Hi Rejoice, In addition to the above replies, please note that there are solid rod libraries already available in the Dutch Steel section database as well as the AISC Steel Profiles (R-Cceco). regards, Madhan
Answer Verified By: Rejoice Serrano
hello sir,
I have been trying to use solid rod profiles in my project (AISC Code) can u please help me to understand how i can create the same in staad pro connect edition.
You can create a solid rod by using the Define button or by adding it from Dutch section database. Both options are explained in the posts above. Note that solid rods in STAAD.Pro can be analyzed, but not designed.
hi sir,
i tried adding it as u said , but after the analysis it says that member property is not supported.
please find the attched staad file and help me do it thanks.
STAAD SPACESTART JOB INFORMATIONENGINEER DATE 08-Oct-22END JOB INFORMATIONINPUT WIDTH 79UNIT FEET KIPJOINT COORDINATES1 0 0 0; 2 4.4 0 0; 3 0 0 5.3; 4 4.4 0 5.3; 7 4.4 -4.4 0; 8 4.4 -4.4 5.3;9 4.4 0 2.65; 10 0 0 2.65; 11 4.4 0 4.8; 12 4.4 0 0.5; 13 4.4 0 3.37;14 4.4 0 1.93;MEMBER INCIDENCES1 1 2; 2 1 10; 3 2 12; 4 3 4; 8 1 7; 9 3 8; 10 9 13; 11 10 3; 12 9 10; 13 11 4;14 12 14; 15 13 11; 16 14 9;START USER TABLETABLE 1UNIT FEET KIPPIPE0.875ROD0.073 0.01 0.0025 0.003ENDDEFINE MATERIAL STARTISOTROPIC STEELE 4.176e+06POISSON 0.3DENSITY 0.489024ALPHA 6.5e-06DAMP 0.03G 1.6128e+06TYPE STEELSTRENGTH RY 1.5 RT 1.2ISOTROPIC STEEL_36_KSIE 4.176e+06POISSON 0.3DENSITY 0.489024ALPHA 6.5e-06DAMP 0.03G 1.6128e+06TYPE STEELSTRENGTH FY 5184 FU 8352 RY 1.5 RT 1.2END DEFINE MATERIALCONSTANTSMATERIAL STEEL ALLMEMBER PROPERTY AMERICAN1 TO 4 10 11 13 TO 16 TABLE ST C8X1112 TABLE ST C6X8MEMBER PROPERTY DUTCH8 9 TABLE ST RD22.25MEMBER RELEASE8 9 12 START MY MZ12 END MY MZ2 START MYSUPPORTS7 8 FIXED BUT MX MY MZ2 4 FIXED BUT MX MY MZ11 TO 14 FIXED BUT FX FZ MX MY MZLOAD 1 LOADTYPE Dead TITLE DLSELFWEIGHT Y -1 MEMBER LOAD12 UNI GY -0.081 4 UNI GY -0.04LOAD 2 LOADTYPE Live TITLE LLMEMBER LOAD12 UNI GY -0.281 4 UNI GY -0.14LOAD 3 LOADTYPE Wind TITLE WL+XMEMBER LOAD2 3 10 11 13 TO 16 UNI GX 0.1418 9 UNI GX 0.018LOAD 4 LOADTYPE Wind TITLE WL-XMEMBER LOAD2 3 10 11 13 TO 16 UNI GX -0.1418 9 UNI GX -0.018LOAD 5 LOADTYPE Wind TITLE WL+ZMEMBER LOAD1 4 UNI GZ 0.1418 9 UNI GZ 0.018LOAD 6 LOADTYPE Wind TITLE WL-ZMEMBER LOAD1 4 UNI GZ -0.1418 9 UNI GZ -0.018*LOAD COMB 3 DL+0.75LL*1 1.0 2 0.75*LOAD COMB 4 DL+LL*1 1.0 2 1.0LOAD COMB 7 DL1 1.0 LOAD COMB 8 DL+LL1 1.0 2 1.0 LOAD COMB 9 DL+0.75LL1 1.0 2 0.75 LOAD COMB 10 DL+0.6WL+X1 1.0 3 0.6 LOAD COMB 11 DL+0.6WL-X1 1.0 4 0.6 LOAD COMB 12 DL+0.6WL+Z1 1.0 5 0.6 LOAD COMB 13 DL+0.6WL-Z1 1.0 6 0.6 LOAD COMB 14 DL+0.75LL+0.45WL+X1 1.0 2 0.75 3 0.45 LOAD COMB 15 DL+0.75LL+0.45WL-X1 1.0 2 0.75 4 0.45 LOAD COMB 16 DL+0.75LL+0.45WL+Z1 1.0 2 0.75 5 0.45 LOAD COMB 17 DL+0.75LL+0.45WL-Z1 1.0 2 0.75 6 0.45 LOAD COMB 18 0.6DL+0.6WL+X1 0.6 3 0.6 LOAD COMB 19 0.6DL+0.6WL-X1 0.6 4 0.6 LOAD COMB 20 0.6DL+0.6WL+Z1 0.6 5 0.6 LOAD COMB 21 0.6DL+0.6WL-Z1 0.6 6 0.6 PERFORM ANALYSIS PRINT ALLPARAMETER 1CODE AISC UNIFIED 2016BEAM 1 ALLCB 0 ALLFYLD 5184 ALLKY 1 MEMB 8 9KZ 1 MEMB 8 9LZ 5.3 MEMB 2 3 10 11 13 TO 16MAIN 200 ALLMETHOD ASDCHECK CODE ALLSTEEL MEMBER TAKE OFF ALLPERFORM ANALYSISFINISH
As I mentioned, STAAD.Pro does not support design of solid rods. You can only analyze it to get the forces and design it manually.
