Glazed Glass Problem
Hello Everyone,
I was doing a study on how the glass panels behave in terms of deflection in modern building structures where the glazed glass panels are provided as order to give a well defined architectural view.
I tried by giving the appropriate glass properties and tested with both plate and surface elements but I found some deflection variation between them being provided with same material properties.
I have attached my model please have a look at it and let me know the actual reason of their result variation and also let me know if it is the correct way for actual consideration for practical case.
Thanks in advance.glass test.std
