Geometry
Hai,
By default STAADPRO is considering the node as the centre of the section size specified.
Can we change that to our requirement. Say I am specifying a column size of 600mm, I want the section to be divided to 200mm on one side and 400mm on other side of the node.  Is there any option to do this.
Thank you.
Parents Reply Children
  • Hai,
    Thankyou Sir,
    I will try increasing the grade or size of those Beams. Before that I will explain my problem clearly.
    I have placed a node in a beam where a secondary beam is joining. So the complete Beam will be divided in to two parts and if you see, the small part of this divided portion is failing. All other longer span beams are passed, But I am having problem with this small divided part of the Beam. Other part of the same beam is passed. Can you please clarify why this is happening.
    And Sorry for the wrong post here sir. Next time it will be in respective topics.
