Hi, I recently just started using staad and this error message " NO LOADING DEFINED FOR UBC LOAD. RUN TERMINATED." is shown. Can you suggest some solutions?
Thank you! :)
This is the output file.
STAAD SPACE DXF IMPORT OF ERXNEWEST.DXFSTART JOB INFORMATIONENGINEER DATE 21-Feb-17END JOB INFORMATIONINPUT WIDTH 79UNIT METER KNJOINT COORDINATES1 0 4 0; 2 4 4 0; 3 8 4 0; 4 12 4 0; 5 16 4 0; 6 0 4 -3; 7 4 4 -3; 8 8 4 -3;9 12 4 -3; 10 16 4 -3; 11 0 4 -7; 12 4 4 -7; 13 8 4 -7; 14 12 4 -7; 15 16 4 -7;16 0 4 -10; 17 4 4 -10; 18 8 4 -10; 19 12 4 -10; 20 16 4 -10; 21 4 7 0;22 8 7 0; 23 12 7 0; 24 4 7 -3; 25 8 7 -3; 26 12 7 -3; 27 0 7 -3; 28 16 7 -3;29 0 7 -7; 30 4 7 -7; 31 8 7 -7; 32 12 7 -7; 33 16 7 -7; 34 0 7 -10;35 4 7 -10; 36 8 7 -10; 37 12 7 -10; 38 16 7 -10; 39 0 0 -10; 40 0 0 -7;41 0 0 -3; 42 0 0 0; 43 4 0 -10; 44 4 0 -7; 45 4 0 -3; 46 4 0 0; 47 8 0 -10;48 8 0 -7; 49 8 0 -3; 50 8 0 0; 51 12 0 0; 52 12 0 -3; 53 12 0 -7; 54 12 0 -10;55 16 0 0; 56 16 0 -3; 57 16 0 -7; 58 16 0 -10;MEMBER INCIDENCES1 1 2; 2 2 3; 3 3 4; 4 4 5; 5 1 6; 6 2 7; 7 3 8; 8 4 9; 9 5 10; 10 6 7; 11 7 8;12 8 9; 13 9 10; 14 6 11; 15 7 12; 16 8 13; 17 9 14; 18 10 15; 19 11 12;20 12 13; 21 13 14; 22 14 15; 23 11 16; 24 12 17; 25 13 18; 26 14 19; 27 15 20;28 16 17; 29 17 18; 30 18 19; 31 19 20; 32 21 22; 33 22 23; 34 21 24; 35 22 25;36 23 26; 37 27 24; 38 24 25; 39 25 26; 40 26 28; 41 27 29; 42 24 30; 43 25 31;44 26 32; 45 28 33; 46 29 30; 47 30 31; 48 31 32; 49 32 33; 50 29 34; 51 30 35;52 31 36; 53 32 37; 54 33 38; 55 34 35; 56 35 36; 57 36 37; 58 37 38; 59 16 39;60 34 16; 61 11 40; 62 6 41; 63 1 42; 64 43 17; 65 44 12; 66 45 7; 67 2 46;68 47 18; 69 48 13; 70 49 8; 71 50 3; 72 51 4; 73 52 9; 74 53 14; 75 54 19;76 55 5; 77 56 10; 78 15 57; 79 20 58; 80 29 11; 81 6 27; 82 17 35; 83 12 30;84 7 24; 85 2 21; 86 18 36; 87 13 31; 88 8 25; 89 3 22; 90 19 37; 91 14 32;92 9 26; 93 4 23; 94 20 38; 95 15 33; 96 10 28;START GROUP DEFINITIONFLOOR_2F1 1 2 5 TO 7 10 11 14 TO 16 19 20 24 25 29_2F2 3 4 7 TO 9 12 13 16 TO 18 21 22 25 TO 27 30 31_ROOF 32 TO 34 36 37 40 TO 42 44 TO 58END GROUP DEFINITIONDEFINE MATERIAL STARTISOTROPIC CONCRETEE 2.17185e+007POISSON 0.17DENSITY 23.5616ALPHA 1e-005DAMP 0.05TYPE CONCRETESTRENGTH FCU 27579END DEFINE MATERIALMEMBER PROPERTY AMERICAN1 TO 58 PRIS YD 0.5 ZD 0.359 TO 96 PRIS YD 0.3 ZD 0.3CONSTANTSMATERIAL CONCRETE ALLSUPPORTS39 TO 58 PINNEDSLAVE ZX MASTER 13 JOINT 1 TO 12 14 TO 20SLAVE ZX MASTER 31 JOINT 24 26 TO 30 32 TO 38DEFINE UBC LOADZONE 0.4 I 1 RWX 8.5 RWZ 8.5 STYP 5 NA 1 NV 1LOAD 1 LOADTYPE Seismic TITLE EQXUBC LOAD X 1PERFORM ANALYSISCHANGELOAD 2 LOADTYPE Seismic TITLE EQZUBC LOAD Z 1PERFORM ANALYSISCHANGELOAD 3 LOADTYPE Dead TITLE DLSELFWEIGHT Y -1FLOOR LOAD_2F1 FLOAD -5 GY_2F2 FLOAD -5 GY_ROOF FLOAD -3 GYMEMBER LOAD1 TO 31 UNI GY -1315 16 20 TO 22 24 UNI GY -9.9LOAD 4 LOADTYPE Live TITLE LLFLOOR LOAD_2F1 FLOAD -2.4 GY_2F2 FLOAD -4.8 GYLOAD COMB 5 1.2DL + 1.6LL3 1.2 4 1.6 LOAD COMB 6 1.2DL + 1.0LL + 1EQX+3 1.2 4 1.0 1 1.0LOAD COMB 7 1.2DL + 1.0LL + 1EQX-3 1.2 4 1.0 1 -1.0LOAD COMB 8 1.2DL + 1.0LL + 1EQZ+3 1.2 4 1.0 1 1.0LOAD COMB 9 1.2DL + 1.0LL + 1EQZ-3 1.2 4 1.0 1 -1.0SELFWEIGHT 1FLOOR LOAD_2F1 FLOAD 5_2F2 FLOAD 5_ROOF FLOAD 3MEMBER LOAD1 TO 31 UNI GY -1315 16 20 TO 22 24 UNI GY -9.9LOAD 1 LOADTYPE DEAD TITLE DLFLOOR LOAD_2F1 FLOAD -2.4 GY_2F2 FLOAD -4.8 GYPERFORM ANALYSISFINISH
Hi Erx,
I have reviewed you model and found missing WEIGHTS in Seismic definition hence this error is displayed and the run is terminated as the program is unable to calculate for the seismic load. I have attached a picture showing the steps you need to follow to solve your problem.
Answer Verified By: Erx Bandigan
STAAD SPACESTART JOB INFORMATIONENGINEER DATE 09-Apr-20END JOB INFORMATIONINPUT WIDTH 79UNIT METER KNJOINT COORDINATES1 0 0 0; 2 0 0 14; 3 22 0 14; 4 22 0 0; 9 0 -1.5 0; 10 0 -1.5 14;11 22 -1.5 14; 12 22 -1.5 0; 14 11 0 0; 15 22 0 7; 19 0 0 7; 21 11 0 14;22 11 -1.5 0; 23 22 -1.5 7; 24 0 -1.5 7; 25 11 -1.5 14; 26 0 5.00001 0;27 0 5.00001 14; 28 22 5.00001 14; 29 22 5.00001 0; 30 11 5.00001 0;31 22 5.00001 7; 32 0 5.00001 7; 33 11 5.00001 14; 34 2.03778 5.00001 4.71849;35 3.31423 5.00001 4.37858; 36 3.7486 5.00001 6.516;37 2.45417 5.00001 10.6967; 38 2.57483 5.00001 9.2249;39 4.35513 5.00001 9.71398; 40 8.99061 5.00001 1.61128;41 10.5115 5.00001 1.94734; 42 9.23516 5.00001 3.42606;43 20.3706 5.00001 3.6642; 44 21.0223 5.00001 2.4889; 45 22 5.00001 2.8;46 1.54853 5.00001 3.40494; 47 2.56831 5.00001 2.07499;48 1.66628 5.00001 1.20223; 49 0 5.00001 2.8; 50 0 5.00001 1.4;51 19.9631 5.00001 11.5628; 52 19.0668 5.00001 10.2666;53 21.0223 5.00001 10.4221; 54 22 5.00001 11.2; 55 20.5878 5.00001 12.7209;56 22 5.00001 12.6; 57 20.2076 5.00001 9.38506; 58 22 5.00001 9.8;59 18.0077 5.00001 4.19998; 60 15.8891 5.00001 3.42221;61 17.5187 5.00001 2.22964; 62 20.6515 5.00001 5.36397;63 20.5334 5.00001 7.46662; 64 18.5509 5.00001 7.89866;65 17.5188 5.00001 9.22951; 66 16.3842 5.00001 9.04511;67 14.1468 5.00001 9.44577; 68 14.3382 5.00001 8.04266;69 18.3607 5.00001 1.38276; 70 19.8 5.00001 0; 71 19.9631 5.00001 1.91854;72 22 5.00001 1.4; 73 19.0669 5.00001 5.91107; 74 14.8028 5.00001 11.9776;75 13.2 5.00001 14; 76 13.1189 5.00001 11.511; 77 14.1864 5.00001 3.23402;78 14.9629 5.00001 4.62054; 79 13.4359 5.00001 4.63206;80 17.5187 5.00001 11.5628; 81 15.8891 5.00001 10.4221;82 17.0571 5.00001 5.66909; 83 9.60621 5.00001 12.3406;84 10.267 5.00001 10.111; 85 11.4621 5.00001 11.8739;86 7.74449 5.00001 8.77752; 87 9.54328 5.00001 9.19514;88 8.14876 5.00001 9.82288; 89 2.36346 5.00001 12.427; 90 0 5.00001 12.6;91 1.23484 5.00001 11.5654; 92 2.2 5.00001 14; 93 4.56346 5.00001 12.3752;94 4.4 5.00001 14; 95 3.86472 5.00001 8.84196; 96 5.29514 5.00001 8.3768;97 3.66701 5.00001 11.511; 98 5.74001 5.00001 11.6894; 99 0 5.00001 9.8;100 1.41475 5.00001 8.91862; 101 8.10969 5.00001 5.67353;102 8.48382 5.00001 7.17656; 103 6.62774 5.00001 7.09786;104 4.88342 5.00001 1.28033; 105 4.64479 5.00001 3.21481;106 3.94785 5.00001 1.80716; 107 4.50747 5.00001 4.53262;108 5.68886 5.00001 4.53638; 109 15.9073 5.00001 12.5134; 110 0 5.00001 11.2;111 8.44441 5.00001 12.8648; 112 6.6 5.00001 14; 113 6.92642 5.00001 12.2542;114 14.0666 5.00001 5.81311; 115 13.2002 5.00001 6.99996;116 11.8696 5.00001 5.13329; 117 7.29765 5.00001 1.21504;118 7.35534 5.00001 3.02623; 119 2.2 5.00001 0; 120 0 5.00001 5.6;121 0 5.00001 4.2; 122 12.9893 5.00001 10.0821; 123 11.7792 5.00001 9.09119;124 0 5.00001 8.4; 125 1.02646 5.00001 7.23187; 126 5.49011 5.00001 10.2774;127 19.094 5.00001 12.3751; 128 22 5.00001 8.4; 129 17.6 5.00001 14;130 22 5.00001 4.2; 131 15.8801 5.00001 1.45189; 132 14.7213 5.00001 2.12594;133 13.3724 5.00001 1.25345; 134 12.8744 5.00001 2.95555;135 12.1955 5.00001 1.63432; 136 11.752 5.00001 3.3454;137 10.1738 5.00001 4.07195; 138 8.8 5.00001 0; 139 15.4 5.00001 14;140 9.59143 5.00001 7.89413; 141 9.53368 5.00001 5.4444;142 10.8014 5.00001 6.03202; 143 7.36032 5.00001 4.31987;144 2.49044 5.00001 7.23228; 145 15.5633 5.00001 5.80736;146 15.7444 5.00001 7.48384; 147 7.22536 5.00001 10.47; 148 22 5.00001 5.6;149 11.0005 5.00001 7.51842; 150 6.30172 5.00001 2.03376;151 5.56266 5.00001 6.0045; 152 19.0668 5.00001 3.26666;153 17.3867 5.00001 7.35693; 154 19.8 5.00001 14; 155 15.4 5.00001 0;156 17.6 5.00001 0; 157 6.60028 5.00001 9.33327; 158 13.2 5.00001 0;159 8.55596 5.00001 11.148; 160 4.4 5.00001 0; 161 6.6 5.00001 0;162 8.8 5.00001 14;MEMBER INCIDENCES1 1 19; 3 3 15; 4 1 14; 13 1 9; 14 2 10; 15 3 11; 16 4 12; 18 14 4; 19 15 4;23 19 2; 25 2 21; 27 21 3; 31 14 22; 32 15 23; 33 19 24; 34 21 25; 35 1 26;36 2 27; 37 3 28; 38 4 29; 39 14 30; 40 15 31; 41 19 32; 42 21 33; 43 26 50;44 28 56; 45 26 119; 46 30 158; 47 31 148; 48 32 124; 49 27 92; 50 33 75;54 45 72; 58 49 121; 60 50 49; 63 54 58; 65 56 54; 68 58 128; 74 70 29;76 72 29; 80 75 139; 87 90 27; 89 92 94; 91 94 112; 95 99 110; 106 110 90;108 112 162; 112 119 160; 114 120 32; 115 121 120; 119 124 99; 123 128 31;126 129 154; 128 130 45; 138 138 30; 141 139 129; 158 148 130; 174 154 28;178 155 156; 179 156 70; 194 158 155; 214 160 161; 215 161 138; 225 162 33;ELEMENT INCIDENCES SHELL51 34 35 36; 52 37 38 39; 53 40 41 42; 55 43 44 45; 56 35 46 47; 57 48 47 46;59 48 46 49; 61 48 50 26; 62 51 52 53; 64 51 53 54; 66 55 56 28; 67 55 51 54;69 57 58 53; 70 59 60 61; 71 62 31 63; 72 64 52 65; 73 66 67 68; 75 69 70 71;77 71 72 44; 78 70 29 72; 79 43 62 73; 81 74 75 76; 82 77 78 79; 83 65 80 81;84 82 60 59; 85 83 84 85; 86 86 87 88; 88 89 90 91; 90 90 92 27; 92 93 94 89;93 95 36 96; 94 93 97 98; 96 37 99 100; 97 101 102 103; 98 34 46 35;99 104 105 106; 100 107 105 108; 101 88 87 84; 102 109 74 81; 103 62 63 73;104 40 30 41; 105 74 76 67; 107 91 110 99; 109 111 112 113; 110 114 115 116;111 117 40 118; 113 106 47 119; 116 34 120 121; 117 85 76 75; 118 122 85 123;120 100 124 125; 121 126 39 96; 122 127 52 51; 124 57 63 128; 125 68 67 123;127 109 80 129; 129 43 130 62; 130 131 60 132; 131 133 134 135; 132 77 60 78;133 135 41 30; 134 136 79 116; 135 89 91 37; 136 93 98 112; 137 137 41 136;139 117 138 40; 140 122 76 85; 142 74 139 75; 143 140 141 142; 144 143 118 42;145 144 100 125; 146 144 38 100; 147 46 121 49; 148 34 125 120;149 142 116 115; 150 86 102 140; 151 114 145 146; 152 82 59 73; 153 147 98 126;154 83 85 33; 155 136 41 135; 156 40 138 30; 157 63 31 128; 159 62 148 31;160 137 116 142; 161 114 116 79; 162 113 112 98; 163 126 97 39; 164 125 32 120;165 125 124 32; 166 91 90 110; 167 89 92 90; 168 66 68 146; 169 123 149 115;170 150 118 108; 171 107 108 151; 172 59 152 73; 173 64 153 73;175 127 154 129; 176 65 52 80; 177 69 71 152; 180 131 155 156; 181 57 52 64;182 66 146 153; 183 126 98 97; 184 96 103 157; 185 106 105 47; 186 48 119 47;187 53 58 54; 188 57 128 58; 189 44 72 45; 190 71 70 72; 191 62 130 148;192 43 45 130; 193 131 61 60; 195 133 158 155; 196 86 140 87; 197 123 84 87;198 83 159 84; 199 85 75 33; 200 107 151 36; 201 35 47 105; 202 101 141 102;203 86 157 103; 204 82 153 146; 205 114 146 68; 206 140 149 123; 207 123 85 84;208 151 103 96; 209 95 144 36; 210 109 139 74; 211 74 67 81; 212 143 42 101;213 137 136 116; 216 104 160 161; 217 150 108 105; 218 114 79 78;219 136 134 79; 220 100 99 124; 221 37 91 99; 222 59 61 152; 223 78 60 82;224 111 113 159; 226 83 33 162; 227 151 96 36; 228 101 103 151;229 111 162 112; 230 147 88 159; 231 133 132 134; 232 135 30 158;233 127 80 52; 234 55 127 51; 235 117 161 138; 236 40 42 118; 237 37 39 97;238 37 100 38; 239 101 42 141; 240 101 151 108; 241 64 73 63; 242 64 65 153;243 68 123 115; 244 66 81 67; 245 82 146 145; 246 82 73 153; 247 136 135 134;248 137 42 41; 249 131 156 61; 250 131 132 155; 251 127 129 80; 252 55 154 127;253 95 38 144; 254 34 36 144; 255 69 156 70; 256 43 152 71; 257 109 129 139;258 109 81 80; 259 89 94 92; 260 89 37 97; 261 57 64 63; 262 57 53 52;263 48 26 119; 264 48 49 50; 265 104 150 105; 266 106 119 160; 267 147 157 88;268 88 84 159; 269 34 121 46; 270 34 144 125; 271 78 82 145; 272 77 132 60;273 69 61 156; 274 69 152 61; 275 43 71 44; 276 43 73 152; 277 117 150 161;278 117 118 150; 279 114 68 115; 280 114 78 145; 281 140 102 141;282 142 115 149; 283 55 28 154; 284 55 54 56; 285 137 141 42; 286 137 142 141;287 66 65 81; 288 66 153 65; 289 147 113 98; 290 126 96 157; 291 77 134 132;292 77 79 134; 293 122 67 76; 294 122 123 67; 295 93 89 97; 296 93 112 94;297 107 35 105; 298 107 36 35; 299 133 155 132; 300 133 135 158;301 111 83 162; 302 111 159 83; 303 143 108 118; 304 143 101 108;305 147 126 157; 306 147 159 113; 307 104 161 150; 308 104 106 160;309 95 39 38; 310 95 96 39; 311 140 123 87; 312 140 142 149; 313 86 103 102;314 86 88 157;ELEMENT PROPERTY51 TO 53 55 TO 57 59 61 62 64 66 67 69 TO 73 75 77 TO 79 81 TO 86 88 90 92 -93 TO 94 96 TO 105 107 109 TO 111 113 116 TO 118 120 TO 122 124 125 127 129 -130 TO 137 139 140 142 TO 157 159 TO 173 175 TO 177 180 TO 193 195 TO 213 -216 TO 224 226 TO 314 THICKNESS 0.12DEFINE MATERIAL STARTISOTROPIC CONCRETEE 2.17185e+007POISSON 0.17DENSITY 23.5616ALPHA 1e-005DAMP 0.05TYPE CONCRETESTRENGTH FCU 27579END DEFINE MATERIALMEMBER PROPERTY AMERICAN1 3 4 18 19 23 25 27 43 TO 50 54 58 60 63 65 68 74 76 80 87 89 91 95 106 108 -112 114 115 119 123 126 128 138 141 158 174 178 179 194 214 215 -225 PRIS YD 0.3 ZD 0.2513 TO 16 31 TO 42 PRIS YD 0.3 ZD 0.3CONSTANTSMATERIAL CONCRETE ALLSUPPORTS9 TO 12 22 TO 25 FIXEDDEFINE 1893 LOADZONE 0.24 RF 5 I 1 SS 1 ST 1 PX 0.6 PZ 0.6LOAD 1 LOADTYPE Seismic TITLE EQX+1893 LOAD X 1LOAD 2 LOADTYPE Seismic TITLE EQX-1893 LOAD X -1LOAD 3 LOADTYPE Seismic TITLE EQZ+1893 LOAD Z 1LOAD 4 LOADTYPE Seismic TITLE EQZ-1893 LOAD Z -1LOAD 5 LOADTYPE Dead TITLE DLSELFWEIGHT Y -1 LIST ALLMEMBER LOAD1 3 4 18 19 23 25 43 TO 49 54 58 60 63 65 68 74 76 87 89 91 95 106 108 112 -114 115 119 123 128 138 158 178 179 194 214 215 225 UNI GY -11.643 TO 50 54 58 60 63 65 68 74 76 80 87 89 91 95 106 108 112 114 115 119 123 -126 128 138 141 158 174 178 179 194 214 215 225 UNI GY -5.5FLOOR LOADYRANGE 0 0 FLOAD -7.8 GYYRANGE 5 5 FLOAD -5.89 GYMEMBER LOAD27 50 80 126 141 174 UNI GY -13.107LOAD 6 LOADTYPE Live REDUCIBLE TITLE LLFLOOR LOADYRANGE 0 0 FLOAD -2 GYYRANGE 5 5 FLOAD -1 GYPERFORM ANALYSIS PRINT ALLPERFORM ANALYSIS PRINT ALLFINISH STAAD SPACESTART JOB INFORMATIONENGINEER DATE 09-Apr-20END JOB INFORMATIONINPUT WIDTH 79UNIT METER KNJOINT COORDINATES1 0 0 0; 2 0 0 14; 3 22 0 14; 4 22 0 0; 9 0 -1.5 0; 10 0 -1.5 14;11 22 -1.5 14; 12 22 -1.5 0; 14 11 0 0; 15 22 0 7; 19 0 0 7; 21 11 0 14;22 11 -1.5 0; 23 22 -1.5 7; 24 0 -1.5 7; 25 11 -1.5 14; 26 0 5.00001 0;27 0 5.00001 14; 28 22 5.00001 14; 29 22 5.00001 0; 30 11 5.00001 0;31 22 5.00001 7; 32 0 5.00001 7; 33 11 5.00001 14; 34 2.03778 5.00001 4.71849;35 3.31423 5.00001 437858; 36 3.7486 5.00001 6.516;37 2.45417 5.00001 10.6967; 38 2.57483 5.00001 9.2249;39 4.35513 5.00001 9.71398; 40 8.99061 5.00001 1.61128;41 10.5115 5.00001 1.94734; 42 9.23516 5.00001 3.42606;43 20.3706 5.00001 3.6642; 44 21.0223 5.00001 2.4889; 45 22 5.00001 2.8;46 1.54853 5.00001 3.40494; 47 2.56831 5.00001 2.07499;48 1.66628 5.00001 1.20223; 49 0 5.00001 2.8; 50 0 5.00001 1.4;51 19.9631 5.00001 11.5628; 52 19.0668 5.00001 10.2666;53 21.0223 5.00001 10.4221; 54 22 5.00001 11.2; 55 20.5878 5.00001 12.7209;56 22 5.00001 12.6; 57 20.2076 5.00001 9.38506; 58 22 5.00001 9.8;59 18.0077 5.00001 4.19998; 60 15.8891 5.00001 3.42221;61 17.5187 5.00001 2.22964; 62 20.6515 5.00001 5.36397;63 20.5334 5.00001 7.46662; 64 18.5509 5.00001 7.89866;65 17.5188 5.00001 9.22951; 66 16.3842 5.00001 9.04511;67 14.1468 5.00001 9.44577; 68 14.3382 5.00001 8.04266;69 18.3607 5.00001 1.38276; 70 19.8 5.00001 0; 71 19.9631 5.00001 1.91854;72 22 5.00001 1.4; 73 19.0669 500001 5.91107; 74 14.8028 5.00001 11.9776;75 13.2 5.00001 14; 76 13.1189 5.00001 11.511; 77 14.1864 5.00001 3.23402;78 14.9629 5.00001 4.62054; 79 13.4359 5.00001 4.63206;80 17.5187 5.00001 11.5628; 81 15.8891 5.00001 10.4221;82 17.0571 5.00001 5.66909; 83 9.60621 5.00001 12.3406;84 10.267 5.00001 10.111; 85 11.4621 5.00001 11.8739;86 7.74449 5.00001 8.77752; 87 9.54328 5.00001 9.19514;88 8.14876 5.00001 9.82288; 89 2.36346 5.00001 12.427; 90 0 5.00001 12.6;91 1.23484 5.00001 11.5654; 92 2.2 5.00001 14; 93 4.56346 5.00001 12.3752;94 4.4 5.00001 14; 95 3.86472 5.00001 8.84196; 96 529514 5.00001 8.3768;97 3.66701 5.00001 11.511; 98 5.74001 5.00001 11.6894; 99 0 5.00001 9.8;100 1.41475 5.00001 8.91862; 101 8.10969 5.00001 5.67353;102 8.48382 5.00001 7.17656; 103 6.62774 5.00001 7.09786;104 4.88342 5.00001 1.28033; 105 4.64479 5.00001 3.21481;106 3.94785 5.00001 1.80716; 107 4.50747 5.00001 4.53262;108 5.68886 5.00001 4.53638; 109 15.9073 5.00001 12.5134; 110 0 5.00001 11.2;111 8.44441 5.00001 12.8648; 112 6.6 5.00001 14; 113 6.92642 5.00001 12.2542;114 14.0666 5.00001 5.81311; 115 13.2002 5.00001 6.99996;116 11.8696 5.00001 5.13329; 117 7.29765 5.00001 1.21504;118 7.35534 5.00001 3.02623; 119 2.2 5.00001 0; 120 0 5.00001 5.6;121 0 5.00001 4.2; 122 12.9893 5.00001 10.0821; 123 11.7792 5.00001 9.09119;124 0 5.00001 8.4; 125 1.02646 5.00001 7.23187; 126 5.49011 5.00001 10.2774;127 19.094 5.00001 12.3751; 128 22 5.00001 8.4; 129 17.6 500001 14;130 22 5.00001 4.2; 131 15.8801 5.00001 1.45189; 132 14.7213 5.00001 2.12594;133 13.3724 5.00001 1.25345; 134 12.8744 5.00001 2.95555;135 12.1955 5.00001 1.63432; 136 11.752 5.00001 3.3454;137 10.1738 5.00001 4.07195; 138 8.8 5.00001 0; 139 15.4 5.00001 14;140 9.59143 5.00001 7.89413; 141 9.53368 5.00001 5.4444;142 10.8014 5.00001 6.03202; 143 7.36032 5.00001 4.31987;144 2.49044 5.00001 7.23228; 145 15.5633 5.00001 5.80736;146 15.7444 5.00001 7.48384; 147 7.22536 5.00001 10.47; 148 22 5.00001 5.6;149 11.0005 5.00001 7.51842; 150 6.30172 5.00001 2.03376;151 5.56266 5.00001 6.0045; 152 19.0668 5.00001 3.26666;153 17.3867 5.00001 7.35693; 154 19.8 5.00001 14; 155 15.4 5.00001 0;156 17.6 5.00001 0; 157 6.60028 5.00001 9.33327; 158 13.2 5.00001 0;159 8.55596 5.00001 11.148; 160 4.4 5.00001 0; 161 6.6 5.00001 0;162 8.8 5.00001 14;MEMBER INCIDENCES1 1 19; 3 3 15; 4 1 14; 13 1 9; 14 2 10; 15 3 11; 16 4 12; 18 14 4; 19 15 4;23 19 2; 25 2 21; 27 21 3; 31 14 22; 32 15 23; 33 19 24; 34 21 25; 35 1 26;36 2 27; 37 3 28; 38 4 29; 39 14 30; 40 15 31; 41 19 32; 42 21 33; 43 26 50;44 28 56; 45 26 119; 46 30 158; 47 31 148; 48 32 124; 49 27 92; 50 33 75;54 45 72; 58 49 121; 60 50 49; 63 54 58; 65 56 54; 68 58 128; 74 70 29;76 72 29; 80 75 139; 87 90 27; 89 92 94; 91 94 112; 95 99 110; 106 110 90;108 112 162; 112 119 160; 114 120 32; 115 121 120; 119 124 99; 123 128 31;126 129 154; 128 130 45; 138 138 30; 141 139 129; 158 148 130; 174 154 28;178 155 156; 179 156 70; 194 158 155; 214 160 161; 215 161 138; 225 162 33;ELEMENT INCIDENCES SHELL51 34 35 36; 52 37 38 39; 53 40 41 42; 55 43 44 45; 56 35 46 47; 57 48 47 46;59 48 46 49; 61 48 50 26; 62 51 52 53; 64 51 53 54; 66 55 56 28; 67 55 51 54;69 57 58 53; 70 59 60 61; 71 62 31 63; 72 64 52 65; 73 66 67 68; 75 69 70 71;77 71 72 44; 78 70 29 72; 79 43 62 73; 81 74 75 76; 82 77 78 79; 83 65 80 81;84 82 60 59; 85 83 84 85; 86 86 87 88; 88 89 90 91; 90 90 92 27; 92 93 94 89;93 95 36 96; 94 93 97 98; 96 37 99 100; 97 101 102 103; 98 34 46 35;99 104 105 106; 100 107 105 108; 101 88 87 84; 102 109 74 81; 103 62 63 73;104 40 30 41; 105 74 76 67; 107 91 110 99; 109 111 112 113; 110 114 115 116;111 117 40 118; 113 106 47 119; 116 34 120 121; 117 85 76 75; 118 122 85 123;120 100 124 125; 121 126 39 96; 122 127 52 51; 124 57 63 128; 125 68 67 123;127 109 80 129; 129 43 130 62; 130 131 60 132; 131 133 134 135; 132 77 60 78;133 135 41 30; 134 136 79 116; 135 89 91 37; 136 93 98 112; 137 137 41 136;139 117 138 40; 140 122 76 85; 142 74 139 75; 143 140 141 142; 144 143 118 42;145 144 100 125; 146 144 38 100; 147 46 121 49; 148 34 125 120;149 142 116 115; 150 86 102 140; 151 114 145 146; 152 82 59 73; 153 147 98 126;154 83 85 33; 155 136 41 135; 156 40 138 30; 157 63 31 128; 159 62 148 31;160 137 116 142; 161 114 116 79; 162 113 112 98; 163 126 97 39; 164 125 32 120;165 125 124 32; 166 91 90 110; 167 89 92 90; 168 66 68 146; 169 123 149 115;170 150 118 108; 171 107 108 151; 172 59 152 73; 173 64 153 73;175 127 154 129; 176 65 52 80; 177 69 71 152; 180 131 155 156; 181 57 52 64;182 66 146 153; 183 126 98 97; 184 96 103 157; 185 106 105 47; 186 48 119 47;187 53 58 54; 188 57 128 58; 189 44 72 45; 190 71 70 72; 191 62 130 148;192 43 45 130; 193 131 61 60; 195 133 158 155; 196 86 140 87; 197 123 84 87;198 83 159 84; 199 85 75 33; 200 107 151 36; 201 35 47 105; 202 101 141 102;203 86 157 103; 204 82 153 146; 205 114 146 68; 206 140 149 123; 207 123 85 84;208 151 103 96; 209 95 144 36; 210 109 139 74; 211 74 67 81; 212 143 42 101;213 137 136 116; 216 104 160 161; 217 150 108 105; 218 114 79 78;219 136 134 79; 220 100 99 124; 221 37 91 99; 222 59 61 152; 223 78 60 82;224 111 113 159; 226 83 33 162; 227 151 96 36; 228 101 103 151;229 111 162 112; 230 147 88 159; 231 133 132 134; 232 135 30 158;233 127 80 52; 234 55 127 51; 235 117 161 138; 236 40 42 118; 237 37 39 97;238 37 100 38; 239 101 42 141; 240 101 151 108; 241 64 73 63; 242 64 65 153;243 68 123 115; 244 66 81 67; 245 82 146 145; 246 82 73 153; 247 136 135 134;248 137 42 41; 249 131 156 61; 250 131 132 155; 251 127 129 80; 252 55 154 127;253 95 38 144; 254 34 36 144; 255 69 156 70; 256 43 152 71; 257 109 129 139;258 109 81 80; 259 89 94 92; 260 89 37 97; 261 57 64 63; 262 57 53 52;263 48 26 119; 264 48 49 50; 265 104 150 105; 266 106 119 160; 267 147 157 88;268 88 84 159; 269 34 121 46; 270 34 144 125; 271 78 82 145; 272 77 132 60;273 69 61 156; 274 69 152 61; 275 43 71 44; 276 43 73 152; 277 117 150 161;278 117 118 150; 279 114 68 115; 280 114 78 145; 281 140 102 141;282 142 115 149; 283 55 28 154; 284 55 54 56; 285 137 141 42; 286 137 142 141;287 66 65 81; 288 66 153 65; 289 147 113 98; 290 126 96 157; 291 77 134 132;292 77 79 134; 293 122 67 76; 294 122 123 67; 295 93 89 97; 296 93 112 94;297 107 35 105; 298 107 36 35; 299 133 155 132; 300 133 135 158;301 111 83 162; 302 111 159 83; 303 143 108 118; 304 143 101 108;305 147 126 157; 306 147 159 113; 307 104 161 150; 308 104 106 160;309 95 39 38; 310 95 96 39; 311 140 123 87; 312 140 142 149; 313 86 103 102;314 86 88 157;ELEMENT PROPERTY51 TO 53 55 TO 57 59 61 62 64 66 67 69 TO 73 75 77 TO 79 81 TO 86 88 90 92 -93 TO 94 96 TO 105 107 109 TO 111 113 116 TO 118 120 TO 122 124 125 127 129 -130 TO 137 139 140 142 TO 157 159 TO 173 175 TO 177 180 TO 193 195 TO 213 -216 TO 224 226 TO 314 THICKNESS 0.12DEFINE MATERIAL STARTISOTROPIC CONCRETEE 2.17185e+007POISSON 0.17DENSITY 23.5616ALPHA 1e-005DAMP 0.05TYPE CONCRETESTRENGTH FCU 27579END DEFINE MATERIALMEMBER PROPERTY AMERICAN1 3 4 18 19 23 25 27 43 TO 50 54 58 60 63 65 68 74 76 80 87 89 91 95 106 108 -112 114 115 119 123 126 128 138 141 158 174 178 179 194 214 215 -225 PRIS YD 0.3 ZD 0.2513 TO 16 31 TO 42 PRIS YD 0.3 ZD 0.3CONSTANTSMATERIAL CONCRETE ALLSUPPORTS9 TO 12 22 TO 25 FIXEDDEFINE 1893 LOADZONE 0.24 RF 5 I 1 SS 1 ST 1 PX 0.6 PZ 0.6SELFWEIGHT 1LOAD 1 LOADTYPE Seismic TITLE EQX+1893 LOAD X 1LOAD 2 LOADTYPE Seismic TITLE EQX-1893 LOAD X -1LOAD 3 LOADTYPE Seismic TITLE EQZ+1893 LOAD Z 1LOAD 4 LOADTYPE Seismic TITLE EQZ-1893 LOAD Z -1LOAD 5 LOADTYPE Dead TITLE DLSELFWEIGHT Y -1MEMBER LOAD1 3 4 18 19 23 25 43 TO 49 54 58 60 63 65 68 74 76 87 89 91 95 106 108 112 -114 115 119 123 128 138 158 178 179 194 214 215 225 UNI GY -11.643 TO 50 54 58 60 63 65 68 74 76 80 87 89 91 95 106 108 112 114 115 119 123 -126 128 138 141 158 174 178 179 194 214 215 225 UNI GY -5.5FLOOR LOADYRANGE 0 0 FLOAD -7.8 GYYRANGE 5 5 FLOAD -5.89 GYMEMBER LOAD27 50 80 126 141 174 UNI GY -13.107LOAD 6 LOADTYPE Live REDUCIBLE TITLE LLFLOOR LOADYRANGE 0 0 FLOAD -2 GYYRANGE 5 5 FLOAD -1 GYLOAD COMB 7 Generated Indian Code Genral_Structures 15 1.5 6 1.5LOAD COMB 8 Generated Indian Code Genral_Structures 25 1.2 6 1.2LOAD COMB 9 Generated Indian Code Genral_Structures 35 1.2 6 1.2 1 1.2LOAD COMB 10 Generated Indian Code Genral_Structures 45 1.2 6 1.2 2 1.2LOAD COMB 11 Generated Indian Code Genral_Structures 55 1.2 6 1.2 3 1.2LOAD COMB 12 Generated Indian Code Genral_Structures 65 1.2 6 1.2 4 1.2LOAD COMB 13 Generated Indian Code Genral_Structures 75 1.2 6 1.2 1 -1.2LOAD COMB 14 Generated Indian Code Genral_Structures 85 1.2 6 1.2 2 -1.2LOAD COMB 15 Generated Indian Code Genral_Structures 95 1.2 6 1.2 3 -1.2LOAD COMB 16 Generated Indian Code Genral_Structures 105 1.2 6 1.2 4 -1.2LOAD COMB 17 Generated Indian Code Genral_Structures 115 1.5LOAD COMB 18 Generated Indian Code Genral_Structures 125 1.5 1 1.5LOAD COMB 19 Generated Indian Code Genral_Structures 135 1.5 2 1.5LOAD COMB 20 Generated Indian Code Genral_Structures 145 1.5 3 1.5LOAD COMB 21 Generated Indian Code Genral_Structures 155 1.5 4 1.5LOAD COMB 22 Generated Indian Code Genral_Structures 165 1.5 1 -1.5LOAD COMB 23 Generated Indian Code Genral_Structures 175 1.5 2 -1.5LOAD COMB 24 Generated Indian Code Genral_Structures 185 1.5 3 -1.5LOAD COMB 25 Generated Indian Code Genral_Structures 195 1.5 4 -1.5LOAD COMB 26 Generated Indian Code Genral_Structures 205 0.9 1 1.5LOAD COMB 27 Generated Indian Code Genral_Structures 215 0.9 2 1.5LOAD COMB 28 Generated Indian Code Genral_Structures 225 0.9 3 1.5LOAD COMB 29 Generated Indian Code Genral_Structures 235 0.9 4 1.5LOAD COMB 30 Generated Indian Code Genral_Structures 245 0.9 1 -1.5LOAD COMB 31 Generated Indian Code Genral_Structures 255 0.9 2 -1.5LOAD COMB 32 Generated Indian Code Genral_Structures 265 0.9 3 -1.5LOAD COMB 33 Generated Indian Code Genral_Structures 275 0.9 4 -1.5PERFORM ANALYSIS PRINT ALLFINISH
sir I have the same error
