steel2.std
Hello Mark,
I reviewed your model and found some syntax error in STAAD input in adding of member properties. I have corrected it please have a look into it, which I have attached belowsteel2 Solved.std
steel having trouble about the member properties not found in table.
whats happening ? :(
On 2/24/17, ARIF AHAMED
wrote:
> Message from Bentley Communities [http://communities.bentley.com/]
> [AUTOMATED MESSAGE; if there is a link below, please follow that if you wish
> to respond to this Communities message.]
> RE: ***Error*** Above line Contains erroneous data ; ***Error*** Reading
> member properties. please help ! :(
> [http://communities.bentley.com/products/structural/structural_analysis___design/f/5932/p/132188/403500#403500]
> ARIF AHAMED
> [http://communities.bentley.com/members/096b633c_2d00_3c0a_2d00_41c0_2d00_9f9b_2d00_5b2e9c371c7d]
> Hello Mark,
> I have attached
> belowcommunities.bentley.com/.../steel2-Solved.std
> Did this answer your question?
> Verify it as the answer
> [http://communities.bentley.com/products/structural/structural_analysis___design/f/5932/p/403500/verifyanswer?ContentTypeId=1] or Reject
> it as the answer
> [http://communities.bentley.com/products/structural/structural_analysis___design/f/5932/p/403500/rejectanswer?ContentTypeId=1]
> View online
> You received this notification because you subscribed to the forum. To
> unsubscribe from only this thread, go here
> [http://communities.bentley.com/products/structural/structural_analysis___design/f/5932/t/132188/mute].
> Flag
> [http://communities.bentley.com/products/structural/structural_analysis___design/f/5932/p/132188/403500?AbuseContentId=10ccb337-2b02-4dc5-b1b5-711ebf9a229f&AbuseContentTypeId=f586769b-0822-468a-b7f3-a94d480ed9b0&AbuseFlag=true] this
> post as spam/abuse.
In your input file, there are some extra spaces between section names which is highlighted below:
MEMBER PROPERTY AMERICAN
5 TO 10 15 TO 20 25 TO 30 TABLE ST W14 x 873
1 TO 4 11 TO 14 21 TO 24 31 TO 42 TABLE ST W21 x 223
Remove these spaces from your input file and it will run without any problem. I also noticed that you have steel members but the load combinations are from ACI table instead of AISC table.
