Please tell me the procedure that we need to follow to tell the staad software to select member sizes in a model?
Thank you.
The Example 01 outlines the process. Please go to the following section of the online Help ( Help > Contents ) from within STAAD.Pro for more details
The model file EXAMP01.STD file can be found within the software installation folder at C:\SProV8i SS6\STAAD\Examp\US
Thank you, I am using IS 800:2007 code, and want to tell the staad software select Indian Sections to my structure only. But I followed one procedure for member selection where it selected AISC sections, instead of IS sections. Please confirm whether the followed procedure is correct or not and I didn't add PROFILE parameter. Please tell me how we go about selecting members both for strength and serviceability criteria.
Following are the input commands
STAAD SPACESTART JOB INFORMATIONENGINEER DATE 20-Feb-17END JOB INFORMATIONINPUT WIDTH 79UNIT METER KNJOINT COORDINATES1 0 0 0; 2 0 0.305 0; 3 0 2.651 0; 4 0 3.81 0; 5 0 5.181 0; 6 19.964 0 0;7 19.964 0.305 0; 8 19.964 2.651 0; 9 19.964 3.81 0; 10 19.964 5.181 0;11 1.143 5.181 0; 12 2.852 5.181 0; 13 5.704 5.181 0; 14 8.556 5.181 0;15 11.408 5.181 0; 16 14.26 5.181 0; 17 17.112 5.181 0; 18 18.821 5.181 0;19 0 0 0.915; 20 0 0.305 0.915; 21 0 2.651 0.915; 22 0 3.81 0.915;23 0 5.181 0.915; 24 19.964 0 0.915; 25 19.964 0.305 0.915;26 19.964 2.651 0.915; 27 19.964 3.81 0.915; 28 19.964 5.181 0.915;29 1.143 5.181 0.915; 30 2.852 5.181 0.915; 31 5.704 5.181 0.915;32 8.556 5.181 0.915; 33 11.408 5.181 0.915; 34 14.26 5.181 0.915;35 17.112 5.181 0.915; 36 18.821 5.181 0.915;MEMBER INCIDENCES1 1 2; 2 2 3; 3 3 4; 4 4 5; 5 6 7; 6 7 8; 7 8 9; 8 9 10; 9 5 11; 10 11 12;11 12 13; 12 13 14; 13 14 15; 14 15 16; 15 16 17; 16 17 18; 17 18 10; 18 19 20;19 20 21; 20 21 22; 21 22 23; 22 24 25; 23 25 26; 24 26 27; 25 27 28; 26 23 29;27 29 30; 28 30 31; 29 31 32; 30 32 33; 31 33 34; 32 34 35; 33 35 36; 34 36 28;35 23 5; 36 30 12; 37 31 13; 38 32 14; 39 33 15; 40 34 16; 41 35 17; 42 28 10;43 4 11; 44 9 18; 45 22 29; 46 27 36; 47 21 3; 48 26 8; 49 2 21; 50 20 3;51 21 5; 52 3 23; 53 7 26; 54 25 8; 55 8 28; 56 26 10;DEFINE MATERIAL STARTISOTROPIC STEELE 2.05e+008POISSON 0.3DENSITY 76.8195ALPHA 1.2e-005DAMP 0.03END DEFINE MATERIALMEMBER PROPERTY AMERICAN49 TO 56 ASSIGN ANGLE43 TO 46 ASSIGN ANGLE DOUBLE9 TO 17 26 TO 42 47 48 ASSIGN BEAM1 TO 8 18 TO 25 ASSIGN COLUMNCONSTANTSMATERIAL STEEL ALLSUPPORTS1 6 19 24 FIXEDMEMBER OFFSET43 45 START 0.123571 0 043 TO 46 END 0 -0.2286 044 46 START -0.123571 0 0MEMBER RELEASE35 TO 48 START MY MZ35 TO 48 END MY MZ9 26 START MPY 0.99 MPZ 0.9917 34 END MPY 0.99 MPZ 0.99MEMBER TRUSS 49 TO 56LOAD 1 LOADTYPE Dead TITLE DLSELFWEIGHT Y -1 LIST 1 TO 48MEMBER LOAD35 TO 42 CON GY -0.34 0.203235 TO 42 CON GY -0.452 0.7112 0LOAD 2 LOADTYPE Snow TITLE SNMEMBER LOAD35 TO 42 UNI GY -0.07 0 0.9069 TO 17 26 TO 34 UNI GY -0.1LOAD 3 LOADTYPE Wind TITLE WL X+VEMEMBER LOAD1 TO 8 18 TO 25 UNI GX 0.145LOAD 4 LOADTYPE Wind TITLE WL X-VEMEMBER LOAD1 TO 8 18 TO 25 UNI GX -0.145LOAD 5 LOADTYPE Wind TITLE WL Z+VEMEMBER LOAD9 TO 17 UNI GZ 0.241 TO 8 UNI GZ 0.12LOAD 6 LOADTYPE Wind TITLE WL Z-VEMEMBER LOAD26 TO 34 UNI GZ -0.2418 TO 25 UNI GZ -0.12LOAD COMB 7 1.5(DL+SN)1 1.5 2 1.5 LOAD COMB 8 1.2(DL+SN+WL X+VE)1 1.2 2 1.2 3 1.2 LOAD COMB 9 1.2(DL+SN-WL X-VE)1 1.2 2 1.2 4 -1.2 LOAD COMB 10 1.2(DL+SN+WL Z+VE)1 1.2 2 1.2 5 1.2 LOAD COMB 11 1.2(DL+SN-WL Z-VE)1 1.2 2 1.2 6 -1.2 LOAD COMB 12 1.5(DL+WL X+VE)1 1.5 3 1.5 LOAD COMB 13 1.5(DL-WL X-VE)1 1.5 4 1.5 LOAD COMB 14 1.5(DL+WL Z+VE)1 1.5 5 1.5 LOAD COMB 15 1.5(DL+WL Z-VE)1 1.5 6 -1.5 LOAD COMB 16 1.0 DL+ 0.35 SN1 1.0 2 0.35 LOAD COMB 17 1(DL+SN)1 1.0 2 1.0 LOAD COMB 18 1DL+0.8SN+0.8WL X+VE1 1.0 2 0.8 3 0.8 LOAD COMB 19 1DL+0.8SN-0.8WL X-VE1 1.0 2 0.8 4 -0.8 LOAD COMB 20 1DL+0.8SN+0.8WL Z+VE1 1.0 2 0.8 5 0.8 LOAD COMB 21 1DL+0.8SN-0.8WL Z-VE1 1.0 2 0.8 6 -0.8 LOAD COMB 22 1DL+1WL X+VE1 1.0 3 1.0 LOAD COMB 23 1DL-1WL X-VE1 1.0 4 -1.0 LOAD COMB 24 1DL+1WL Z+VE1 1.0 5 1.0 LOAD COMB 25 1DL-1WL Z-VE1 1.0 6 -1.0 PERFORM ANALYSIS LOAD LIST 7 TO 16PARAMETER 1CODE IS800 LSDCMX 0.4 MEMB 1 TO 8 18 TO 25CMY 0.4 MEMB 1 TO 8 18 TO 25CMZ 0.4 MEMB 1 TO 8 18 TO 25FU 410000 ALLKX 1.2 MEMB 9 TO 17 26 TO 34LAT 1 MEMB 9 TO 17 26 TO 42KY 0.8 MEMB 43 TO 56KZ 0.8 MEMB 43 TO 56LX 2.852 MEMB 9 TO 17 26 TO 34LX 0.915 MEMB 35 TO 42LY 2.5905 MEMB 1 TO 8 18 TO 25LZ 3.81 MEMB 1 TO 3 5 TO 7 18 TO 20 22 TO 24LZ 1.371 MEMB 4 8 21 25LY 1.369 MEMB 43 TO 46LZ 1.369 MEMB 43 TO 46LY 1.943 MEMB 49 50 53 54LZ 1.943 MEMB 49 50 53 54LY 2.04 MEMB 51 52 55 56LZ 2.04 MEMB 51 52 55 56LY 0.713 MEMB 47 48LZ 0.713 MEMB 47 48TRACK 2 ALLSELECT ALLPARAMETER 2CODE IS800 LSDCHECK CODE ALLFINISH
Thank you
Hi Nageshwar,
For selecting Indian section, you need to replace
with
MEMBER PROPERTY INDIAN...
The following modifications applied in your file.
1. ***WARNING: THE VALUE OF MOMENT AMPLIFICATION FACTORS KY OR KZ IS GREATER THAN 1.4 FOR MEMBER # 46 FOR LOADCASE- 7. SECOND-ORDER ELASTIC ANALYSIS MUST BE PERFORMED AS PER SECTION 4.4.2 of IS800-2007. ALSO, ENSURE THAT THE TYPE OF COMBINATION USED IS REPEAT LOAD OR REFERENCE LOAD INSTEAD OF THE LOAD COMBINATION SYNTAX EXCEPT FOR RESPONSE SPECTRUM LOAD CASES.
Second order P-Delta analysis command has been added instead of first order analysis. *PERFORM ANALYSIS
PDELTA 15 ANALYSIS LARGEDELTA
2. All LOAD COMBINATION replaced with REPEAT LOAD necessary for P-Delta analysis.
3. Four GROUP (Ax) commands have been added after SELECT to instruct STAAD to select same section for all the assigned members in a GROUP command.
4. Another ANALYSIS command added so that analysis can be performed based upon the selected sections.
Now you will be able to see the results in Post-processing > Beam > Unity Check. Also the selected sections will be available in Property dialog box but need to be assigned manually.
The modified with above changes is attached for your reference.
user's model.std
