A problem about the note *** NOTE: THE TOTAL WEIGHT OF THE STRUCTURE CONSIDERED FOR BASE SHEAR CALCULATION ALONG GLOBAL Z DIRECTION IS NEGLIGIBLE.
Dear Members,
Please help me to learn about the problem BASE SHEAR CALCULATION ALONG GLOBAL Z DIRECTION IS NEGLIGIBLE.
I mention the brief information about my model as follows in pewit to point:.........
01) I create RC model in V8i SS6.
02) The frame of model is not fully orthogonal in X and Z axes.
03) Use Reference Load type Mass without -ve sign, Rigid Floor Diaphragm, UBC-94 Seismic definition
04) Provide Seismic weight by Reference Loads in X, Y. and Z directions with the factor 1 for DL and 0.5 for LL
05) I try to find out, a) Soft Story as per ASCE7, b) Story Shear c) Story Drift  with Limit L/250
06) I provide Static Seismic Analysis.
My confusions in  this model are...........
A). Why the Base shear calculation along Global Z direction is negligible?
B). Why the Story Shear is missing?
C).Am I right in the case of soft story checking?
Please, help to know me  also, which are the out of my questions but helpful.
NB: For more information, I attached my STAAD file here. STR_RE-05_07_Frame.std
  • You mentioned about having floor diaphragms, reference loads in your points 3 and 4 but I do not see these in the model you attached. Softstory check as per ASCE can only be carried out if floor diaphragms are defined. The base shear in Z is comparable with that in X for the model you attached. Story shear is missing as you do not have the PRINT LOAD DATA with the PEEFORM ANALYSIS command. So basically use PERFORM ANALYSIS PRINT LOAD DATA instead of just PEERFORM ANALYSIS and you should have the Story shears reported in the analysis output file. To get Story Drift you need to add PRINT STORY DRIFT command. So here is what you can use
    PRINT STORY DRIFT 0.004
    Answer Verified By: JOTY
Reply
  • Sir,
    I am extremely sorry, I have a mistake to attaching the staad file. I wanted to attach the file "STR_RE-06_02" but by a mistake I attached the file STR_RE-05_07_Frame.std. So, kindly check my new attaching file.
    Thanks sir, for the kind reply.
    3858.STR_RE-06_02.std
    NB: Previous information will be complied for this new attaching file.
    joty
  • I did not see any generated seismic loads applied in your cases 1 to 4. As part of these cases, you have only specified reference loads. There has to be a UBC load applied to get the software to do the seismic load generation. For example as part of your load case 1 you have specified
    LOAD 1 LOADTYPE Seismic TITLE EQ +VE X
    REFERENCE LOAD
    R1 1.0 R2 1.0 R3 1.0 R4 1.0
    PERFORM ANALYSIS
    CHANGE
    You should instead specify
    UBC LOAD X 1
    PERFORM ANALYSIS
    CHANGE
    You do not need to add the reference loads again as part of the seismic load case. Similar changes need to be made to the other seismic cases as well.
    Also for equivalent static seismic load generation, you do not need to specify seismic weights in X and Z within the Seismic definition. Specifying these in Y is good enough. So you may take out the ones in X and Z as shown next
    DEFINE UBC LOAD
    ZONE 0.15 I 1 RWX 8 RWZ 8 CT 0.073 PX 1.072 PZ 1.072 S 1.5
    REFERENCE LOAD Y
    R1 1.0 R2 1.0 R3 1.0 R4 1.0 R5 1.0 R6 0.5 R7 0.25 R8 0.5
    *REFERENCE LOAD Z
    *R1 1.0 R2 1.0 R3 1.0 R4 1.0 R5 1.0 R6 0.5 R7 0.25 R8 0.5
    *REFERENCE LOAD X
    I think I already answered your other queries in my last post.
