Ram Concept - Generate Strips
I am trying to check a two way slab in RAM Concept.  When I push the generate strips button I get the following error.  Has anyone seen this before?
  • At this point the program is determining the width of the design strips. If there are no boundary polylines and the strips are "full width", this is just a process of expanding the strips to meet to the median line.  If two span segments approach a single point the resulting strip widths are tiny and the last section is too narrow so it's simple discarded. Review the cross sections after generating strips and running the calc all to assess the situation further and decide if the span segment layout needs to be changed or not.
    For more see:
