Hi Everyone, can i ask you question..
I have a project, it is design a platform for water intake pump.
The questions is:
1. Is it input for my model correct?
2. I can't find amplitude from pump specification, is it 24840 (kg) - 20700 (kg) = 4140 kg?
3. If Amplitude 4140 kg (41.4 kN), my time history displacement is 0.282 mm and it is out from govern for the project specification.. (CHECK MY WORD FILE)
I hope someone can help me explain about dynamic load analysis and amplitude that should i use for this project, based on pump specification.
Thank you very much, Regards.
Answer Verified By: satrio wityanto
Dear Sye
Thanks for your reply. I already know why my time history displacement is out of my project specification (very big). I put FX and FZ for Time Load before.. in fact, i should only use FY and MY in time load. If you dont mind, please check my latest STD file.
Thank you very much for your concern.C-H00-13M2-201-N - Platform - Dynamic (140317).std
https://marinerspoint.in/centrifugal-pump-parts-working-diagram/
