Hi.
I'm currently working on a 24m-weighbridge platform.
However, the initial output resulted to several instabilities.
I have eliminate the instabilities but could someone guide/enlighten me how should I avoid or correct this?
Thanks in advance.
Here it is:
STAAD SPACE
START JOB INFORMATION
ENGINEER DATE 22-Mar-17
ENGINEER NAME X
END JOB INFORMATION
UNIT METER KN
JOINT COORDINATES
1 0.245 1.925 0.2; 2 1.445 1.925 0.2; 3 0.245 1.925 6; 4 1.445 1.925 6;
5 0 1.925 12; 6 1.445 1.925 12; 7 0 1.925 17.6; 8 1.445 1.925 17.6;
10 0.245 1.925 24; 11 1.745 1.925 24; 12 0.245 2.725 21.5;
13 1.745 2.725 21.5; 14 0.245 2.725 23.1; 15 1.745 2.725 23.1;
16 0.245 3.325 18.7; 17 1.745 3.325 18.7; 18 0.245 3.325 20.4;
19 1.745 3.325 20.4; 20 0 3.76 17.6; 21 0.245 3.76 17.6;
22 1.445 3.76 17.6; 23 1.745 3.76 17.6; 24 0.245 3.925 15.95;
25 1.745 3.925 15.95; 26 0.245 3.925 17.6; 27 1.445 3.925 17.6;
28 1.745 3.925 17.6; 29 0.245 4.525 13.2; 30 1.745 4.525 13.2;
31 0.245 4.525 14.85; 32 1.745 4.525 14.85; 33 0.245 4.96 0.2;
34 1.445 4.96 0.2; 35 1.745 4.96 0.2; 36 0.245 4.96 6; 37 1.445 4.96 6;
38 1.745 4.96 6; 39 0 4.96 12; 40 0.245 4.96 12; 41 1.445 4.96 12;
42 1.745 4.96 12; 43 0.245 5.125 0; 44 1.745 5.125 0;
45 0.245 5.125 0.2; 46 1.745 5.125 0.2; 47 0.245 5.125 2;
48 1.745 5.125 2; 49 0.245 5.125 4; 50 1.745 5.125 4; 51 0.245 5.125 6;
52 1.445 5.125 6; 53 1.745 5.125 6; 54 0.245 5.125 8; 55 1.745 5.125 8;
56 0.245 5.125 10; 57 1.745 5.125 10; 58 0.245 5.125 12;
59 1.445 5.125 12; 60 1.745 5.125 12; 61 0.245 5.125 12.35;
62 1.745 5.125 12.35; 64 0.245 3.375 0.2; 65 1.445 3.375 0.2;
66 0.245 3.375 6; 67 1.445 3.375 6; 68 0 3.375 12; 69 1.445 3.375 12;
MEMBER INCIDENCES
1 14 10; 2 15 11; 3 12 13; 4 12 14; 5 13 15; 6 14 15; 7 7 20; 8 8 22;
9 18 12; 10 19 13; 11 16 17; 12 16 18; 13 17 19; 14 18 19; 15 1 64;
16 2 65; 17 3 66; 18 4 67; 19 5 68; 20 6 69; 22 26 16; 23 28 17;
24 20 21; 25 21 22; 26 22 23; 27 24 25; 28 24 26; 29 25 28; 30 26 27;
31 27 28; 32 31 24; 33 32 25; 34 29 30; 35 29 31; 36 30 32; 37 31 32;
38 61 29; 39 62 30; 40 33 34; 41 34 35; 42 36 37; 43 37 38; 44 39 40;
45 40 41; 46 41 42; 47 43 44; 48 43 45; 49 44 46; 50 45 47; 51 46 48;
52 47 48; 53 47 49; 54 48 50; 55 49 50; 56 49 51; 57 50 53; 58 51 52;
59 52 53; 60 51 54; 61 53 55; 62 54 55; 63 54 56; 64 55 57; 65 56 57;
66 56 58; 67 57 60; 68 58 59; 69 59 60; 70 58 61; 71 60 62; 72 64 33;
73 65 34; 74 64 65; 75 66 36; 76 67 37; 77 66 67; 78 68 39; 79 69 41;
80 68 69; 81 1 65; 82 64 34; 83 3 67; 84 66 37; 85 5 69; 86 68 41;
87 7 22; 88 43 48; 89 48 49; 90 49 53; 91 53 54; 92 54 57; 93 57 58;
94 29 32; 95 25 26; 96 16 19; 97 13 14;
DEFINE MATERIAL START
ISOTROPIC STEEL
E 2.05e+008
POISSON 0.3
DENSITY 76.8195
ALPHA 1.2e-005
DAMP 0.03
TYPE STEEL
STRENGTH FY 253200 FU 407800 RY 1.5 RT 1.2
END DEFINE MATERIAL
MEMBER PROPERTY EUROPEAN
88 TO 97 TABLE ST L60X60X6
MEMBER PROPERTY COLDFORMED EUROPEAN
74 77 80 TO 87 TABLE ST CHS48.3X3
1 2 4 5 9 10 12 13 22 23 28 29 32 33 35 36 38 39 47 TO 51 53 54 56 -
57 60 61 63 64 66 67 70 71 TABLE ST UPN240
3 6 11 14 27 30 31 34 37 52 55 58 59 62 65 68 69 TABLE ST IPE100
8 15 TO 18 20 24 TO 26 40 TO 46 72 73 75 76 79 TABLE ST HE100A
7 19 78 TABLE ST 150X5SHS
CONSTANTS
BETA 180 MEMB 2 5 10 13 23 29 33 36 39 47 49 51 54 57 61 64 67 71
MATERIAL STEEL ALL
SUPPORTS
1 TO 8 10 11 PINNED
MEMBER RELEASE
8 73 76 79 END MY MZ
MEMBER TRUSS
81 TO 97
SLAVE FY MASTER 33 JOINT 45
SLAVE FY MASTER 35 JOINT 46
SLAVE FY MASTER 36 JOINT 51
SLAVE FY MASTER 38 JOINT 53
SLAVE FY MASTER 40 JOINT 58
SLAVE FY MASTER 42 JOINT 60
SLAVE FY MASTER 21 JOINT 26
SLAVE FY MASTER 23 JOINT 28
LOAD 1 LOADTYPE Dead TITLE DEAD LOAD SELFWEIGHT (GS)
SELFWEIGHT Y -1
LOAD 2 LOADTYPE Dead TITLE DEAD LOAD GRATING, KICK PLATES (GO)
MEMBER LOAD
1 2 4 5 9 10 12 13 22 23 28 29 32 33 35 36 38 39 48 TO 51 53 54 56 -
57 60 61 63 64 66 67 70 71 UNI GY -0.75
LOAD COMB 1001 1.35(GS+GO)
1 1.35 2 1.35
LOAD COMB 1002 1.35(GS+GO) + 1.5Q
PERFORM ANALYSIS
DEFINE ENVELOPE
1001 1002 ENVELOPE 1000 TYPE STRENGTH
END DEFINE ENVELOPE
LOAD LIST ENV 1000
PARAMETER 1
CODE EN 1993-1-1:2005
NA 1 MEMB 1 TO 20 22 TO 39 41 43 47 TO 68 70 TO 73 75 76 78 79
SGR 2 MEMB 1 TO 20 22 TO 73 75 76 78 79
SGR 0 MEMB 74 77 80 TO 97
TRACK 0 ALL
CHECK CODE ALL
FINISH
In the model, you have specified few members as truss member using the command MEMBER TRUSS. Truss members are able to carry only the axial forces and no shears or moments, so the load applied on the structure is not able to make its way into the supports because no paths exist for the load to flow through. For that reason there are several instability warning messages. An instability is a condition where a load applied on the structure is not able to make its way into the supports because no paths exist for the load to flow through, and may result in a lack of equilibrium between the applied load and the support reaction.You can define the members as truss members by partially releasing (partial moment releases with 1% fixity) the moments at the start and the end nodes. For more details please go through the following Wikicommunities.bentley.com/.../2046.staad-pro-instability-and-zero-stiffness-faq
RAJAT
Answer Verified By: Sye
