I am creating a model where a specific set of supports is active for specific set of load cases, but then other support points are active for a select portion of those load cases. Is there a way to do this without creating separate models?
It appears doable with the CHANGE command and a renaming of support points after that, but I can't tell graphically or in the results that the model is actually analyzed in this manner.
Please refer to the wiki below for the answer to your query
