Could you please confirm the following understanding of the Staad results,
The total axial force in a column(physical member) is equal to the sum of all the analytical member axial forces.
Or is there any way to find the axial force in the physical member?
Thank you.
You do NOT need to add the axial forces in each segment to get the total axial force in the physical member. Rather to get the axial force at any location within the physical member, consider the axial force in the corresponding analytical member at the appropriate location. For example let us assume a single physical column member which had to be split into 3 segments for some reason. To get the axial force at the base of the physical column, you would just look at the axial force at the base of the bottommost analytical member.
Can I extract Physical member end forces using openstaad macro in excell
