I'm trying to create a small industrial shelter using (a not-typical type of) tubes.
When I inputted it in the user table and then I tried to generate a render model.
The output view was wrong.
Could somehow explain to me where did I make a mistake? I hope to correct it.
The properties also I obtained from the website hence, the "Calculate" button was not used.
Thank you in advance.
My mistake. Thank you.
When I check the units (using Change Graphical Display Unit), section units are displayed as cm but not in meters.
Could we change the units on the user table?
I am using this type of tube, please see below. Is this possible to use in STAAD?
