Why my STAAD Pro analysis saying that my first line is not starting with "STAAD" while it's clearly showing STAAD SPACE ..... in the first line. Here is what shown in the output file of that run. I see there are some symbols in front of my first line, which is invisible in the Editor and I don't know how to get rid of. Please help!
1. STAAD SPACE 24FT STANDARD CO MODULE ASSEMBLYINPUT FILE: C:\Users\Xiaoxia\Documents\JMI\STAAD FILES\Module24ft.STD *** ERROR *** ABOVE COMMAND IS NOT RECOGNIZED. LINE IGNORED. DATA-CHECK MODE IS ENTERED. *********** END OF THE STAAD.Pro RUN ***********
I had faced same issue here. How you resolved it? Please advise.
Open the editor file and check the first line. It should have,
STAAD SPACE
If you see some additional character please delete and save the file.
Else please upload the file to investigate at our end.
