Why my STAAD Pro analysis saying that my first line is not starting with "STAAD" while it's clearly showing STAAD SPACE ..... in the first line. Here is what shown in the output file of that run. I see there are some symbols in front of my first line, which is invisible in the Editor and I don't know how to get rid of. Please help!
1. STAAD SPACE 24FT STANDARD CO MODULE ASSEMBLYINPUT FILE: C:\Users\Xiaoxia\Documents\JMI\STAAD FILES\Module24ft.STD *** ERROR *** ABOVE COMMAND IS NOT RECOGNIZED. LINE IGNORED. DATA-CHECK MODE IS ENTERED. *********** END OF THE STAAD.Pro RUN ***********
Sir, there is no special character in my staad file, even they this bug repeating in Series 6.
I tried this option. But still same error is there.
Have you tried the steps described above? if yes, can you upload the file please?
Thanks & regards,
Abhisek M
Global Technical Support
Subscribe Here
I had faced same issue here. How you resolved it? Please advise.
This worked me fine
Step 1 : Opening the staad model file with Notepad
Step 2: Saving as option
Step 3: Change Encoding at the bottom to ANSI Format from UTF-8 format.
Step 4 : Now open the file with staad application.
It must open without the file recognition error and also we should be able to Run the file without error. Please let know if not working.
Thanks for helping.
Stanleyjones Vincent
