STAAD Foundation能计算基础抗拉吗?验算类似通信塔基础受拉。
Translation of your question : Is STAAD Foundation able to compute foundation under tension? It is to calculate and check the foundations’ capacity under tension, such as communication tower’s foundations.
Response : Yes. STAAD Foundation can design footings subjected to tension. If the tension results in partial loss of contact with the soil, the software can adjust the pressure based on the actual contact area and design the footing accordingly.
Thanks for your answer,The situation what you said is not the my question meaning,the situation what I want to check is similar to regulation 7.2.4 in ANSI-TIA-EIA-222-F-1996.
