RAM Connection Beam Setback Assignment
I am using RAM Connection integrated with STAAD.Pro V8i and am running into an inconvenient issue with setbacks in my connections.
1. I have created several custom templates where I have clearly defined the beam setback "sb" and checked it in both the GUI and the .con text file, however once assigned the setbacks automatically default to 0".
2. Once I manually enter the setbacks, if I alter the beam/girder configuration on any connection, every setback I have manually defined throughout the model defaults back to 0".
Are either of these known issues? I am trying to make these standard connections for my colleagues to use and it would be less than desirable to have them do any alteration to the connections once they're assigned.
  • Hi Seth,
    How’s about loads, like minimum shear and axial loads that we manually added to the loading list inside Ram Connection?  They are erased every time we re-run Staad analysis too.  What is the best way to handle this with Ram Connection that use together with Staad, not Stand-alone Ram.  Thanks.
    Nathan Le, P.E.
    Senior Structural Engineer
    Office: 918.895.6766
    Professional Engineering
    And Project Management
    Oklahoma Office
    2121 S. Colombia Ave, Ste. 600
    Tulsa, OK 74114
    Arkansas Office
    2646 E. Joyce Blvd, Ste. 2
    Fayetteville, AR 72703
    CONFIDENTIALITY NOTICE:  The contents of this email message and any attachments are intended solely for the addressee(s) and may contain confidential and/or privileged information and may be legally protected from disclosure. If you are not the intended recipient of this message or their agent, or if this message has been addressed to you in error, please immediately alert the sender by reply email and then delete this message and any attachments. If you are not the intended recipient, you are hereby notified that any use, dissemination, copying, or storage of this message or its attachments is strictly prohibited.
  • Loads are taken from the Staad.Pro analysis. We don't let the user override this in a permanent way since the analysis is being rerun all the time.  The idea of "minimum design loads" has some appeal, and it was a feature in Limcon. I'll pass along the request.
  • We understood the concern of overriding the loads.  We just added additional loads (minimum design loads in this case) on top of a list of loads directly from Staad.Pro analysis.  Thanks.
    Nathan Le
