Bentley Communities
Site
Search
User
Site
Search
User
Product Communities
RAM | STAAD | ADINA
RAM | STAAD Forum
STAAD Error on design of beam with cover plate
Sign In
State
Suggested Answer
Replies
Answers
Subscribers
110 subscribers
Views
Users
0 members are here
beam
coverplate design
coverplate
Offline
Shahnawaz Shaikh
over 6 years ago
I am getting error in designing beam with cover plate.
9m.std
I am using (SS6 20.07.11.33).
0
Offline
Modestas
Mon, Apr 10 2017 3:04 AM
The design if I sections with cover plates was not available in STAAD.Pro build 20.07.11.33. Please upgrade to the latest STAAD.Pro version (20.07.11.82) where this design will be performed.
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Reject Answer
Cancel
0
Amitava
Mon, Apr 10 2017 3:29 AM
It seems your primary concern is failing of the member in code checking. I have checked with SS6 - Build Number 20.07.11.82 and it is failing there too with a ratio of 1.767. This is not an error in program, rather this is an information on the failure of a member in code checking.
If you go for a detailed design output by providing a TRACK 2 command in the list of design parameters, you will find that the member primarily failed in Major Axis Bending, and also in the associated interaction equations. So, you need to increase the Major Axis Bending Capacity of this beam.
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Reject Answer
Cancel
0
Offline
Shahnawaz Shaikh
Tue, Apr 11 2017 12:23 AM
in reply to
Modestas
Thanks a lot. I will upgrade to the latest version.
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
0
Offline
Shahnawaz Shaikh
Tue, Apr 11 2017 12:24 AM
in reply to
Amitava
Thank you. Actually in my build, it was not showing the interaction ratio. Figured out, that its the bug in the build and is resolved in latest build.
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
