Good Day Everyone,
I have completed a staad model of a staircase, however I have been recieving the following error from the shear wall design results "FAILED:NO REBAR IS AVAILABLE FOR VERTICAL REINFORCEMENT". Does any one know why this would occur? I have added the Staad file as a reference as well.
simply supported stairs.zip
I have added TWO 1 ALL parameter in shear wall design to instruct the program to use two layered reinforcement. This resolves the problem. The modified model has been attached.
6371.simply supported stairs.std
