Another thing I've encountered is that my reinforcement for concrete did not show in the property log after double clicking on the beam,also the option to click for concrete design was missing after double clicking on column to show properties... But all analysis were seen...how can I solve the above complain? Thanks as I'll be waiting for an helpful response.
Hello Sir, thanks for the help in past years and I'm glad to tell you I've improved a little on my staad skills.
However,I would like to have a solution to my little difficulty in staad recently.
1) My CAD file is usually small when imported to staad, that I'll have to zoom n zoom before I could work with it.(I've tried changing the unit to the one of cad file yet it's still the same). Please help me regarithis difficulty.
2) if I'm applying my floor load to a model that has hollow(void)in in the middle or rather a complex structure, the load tends to cover the whole structure including the portion (void)that it's not assigned to.
I'll be glad if I can find a solution to this as it will help improving my skill in future when I needed it most.
