Extracting Forces from STAAD using DotNet
Please could someone help me in extracting forces from STAAD using DotNET?
Not able to extract Primary LoadCase number for extracting Forces.
here is my sample code:
       ' Get BeamLIST
        Dim myBeamNos As Integer = myStaadObj.Geometry.GetMemberCount
        ' Get LoadCase Numbers
        Dim myLoadCasesCount As New Integer
        myLoadCasesCount = myStaadObj.Load.GetLoadCombinationCaseCount
        'Get Primary Load Case Numbers
        Dim myLoadCaseList() As Integer = Nothing
        myStaadObj.Load.GetLoadCombinationCaseNumbers(myLoadCaseList)
        ReDim myLoadCaseList(myLoadCasesCount)
        Dim myLoadCases As Integer = myLoadCaseList(0)
