Create user table and Section wizard
Hi
Could you please tell me what are create user table and section wizard used for and difference between them?
And how do we use them?
Thank you.
Parents Reply
  • Within the American Section Database in STAAD.Pro, there are B shapes which are beams (girders) of large depths. If you need deeper than that, you can always add new B shapes to the existing section database. The procedure for that is outlined in the wiki below ( please click on the Download button to download the document. You have to be logged in to be able to download. )
    Regarding stiffeners, you may not need to model those but you can account for those in the design phase. For example when designing as per the AISC UNIDIED 2010 code ( AIDC 360-10 ) you can define a parameter called STIFF and set it to the stiffener spacing.
